Old 10-10-2015, 10:35 AM   #51
Originally Posted by boowho View Post
P.S. Thank God for this forum. Without it, we'd be in deep "stuff".
X2
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-10-2015, 10:38 AM   #52
Originally Posted by silver View Post
Boo,
If you read my story did you catch the fact that they but a new four bolt hub in even after I told them about the problem.
I did and I thought it was strange. If I remember correctly Tom had his changed to a 5 bolt hub. I do know that before I leave this Thursday I plan to attempt to wiggle my fat butt up into the engine compartment and take a serious look at it. I will bring a wrench and check the bolts and all of the hoses and clamps. Scary stuff. Boo as yours and mine are so close in numbers if I see anything I'll let you know.
Old 10-11-2015, 08:02 PM   #53
silver's Avatar
Opened the engine hatch this weekend and reviewed all the work that was done. Actually looks good. The radiator was removed from the back rather than from below as I thought it would be. Looks like it was cut out as every stud and bracket was new. I bet I have over 20 new studs welled onto the frame where the old ones were cut out. Frame members around the new radiator were painted and I have a shiny new electric clutch. That is what started all this. So even though they were slow to get on board and did not do a complete install, the work done looks pretty good. Still need to test freezing point of the coolant.
silver is offline   Reply With Quote
Old 10-11-2015, 08:44 PM   #54
Silver I'm sure it was a relief to see the quality work done. As handy as you are and the amount of time and energy you have into your MH I m sure it's difficult to hand it over to someone else to do the work. Nice to hear it was done correctly and that issue should be behind you.
berkshire
