Old 08-26-2015, 04:05 PM   #1
silver's Avatar
Berkshire Radiator
Had a foreign object go through my Berkshire radiator. I am now getting a new one. Anyone done this before? I am waiting on the quote and wondering what to expect. I know it will not be cheep.
silver is offline   Reply With Quote
Old 08-26-2015, 04:07 PM   #2
Bummer. What kind of object ? Do you have any idea ?
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 08-26-2015, 04:13 PM   #3
15berkxl's Avatar
Rear or side mount radiator
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 08-26-2015, 05:14 PM   #4
Campin Cajun's Avatar
Has to be rear, no Berks with side radiators.
Did you back into something or did something run into you? And I believe you are right in assuming that it won't be a cheap fix.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 08-26-2015, 05:18 PM   #5
A friend with a Monaco side radiator replaced his at a cost of 6000.00. Hope yours isn't that bad Silver.
Old 08-26-2015, 08:40 PM   #6
silver's Avatar
The electric fan clutch bracket broke and I think a piece of it was blown through the radiator.
Old 08-26-2015, 08:42 PM   #7
silver's Avatar
Hay Phil,
I just had a thought what that basket is worth.
Old 08-26-2015, 08:42 PM   #8
You might want to talk to FL about that. I think they have a known issue with 4 bolt fan mounts.
Old 08-26-2015, 08:42 PM   #9
Phil's gone. Never heard of the guy.
Old 08-26-2015, 09:16 PM   #10
CAT-RN's Avatar
Not sure how big the hole is. I've had our radiator shop repair some seriously damaged radiators on our stationary motors.
Russell
CAT-RN is offline   Reply With Quote
Old 08-27-2015, 03:50 PM   #11
Silver how did you make out with your situation ? Was it repairable ?
Joe & Lori
Old 08-28-2015, 12:01 PM   #12
billygo3251's Avatar
What radiator cost 6000 dollars?
billygo3251 is offline   Reply With Quote
Old 08-28-2015, 01:54 PM   #13
One in a 1986 Monaco.
Old 08-28-2015, 06:12 PM   #14
silver's Avatar
Cummins is having second thoughts about working on it but re-evulating their position. They are not sure how to remove the radiator. I called the local FreightLiner shop and was told "we will not work on it and will not tell you why" then hung up (great customer service).
Old 08-28-2015, 06:20 PM   #15
What? That's outrageous.
Old 08-28-2015, 06:28 PM   #16
tmmar's Avatar
X2!! Call the help line (800-FTL-HELP) and complain to them and see if they can help you.
Tom and Margaret
2014 Berkshire 390bh-60
Old 08-28-2015, 06:56 PM   #17
Tinkerer and Putterer
I've heard more than one person report that a shop refused to work on a rear engined diesel MH. They don't want the liability of working in the interior of a luxury coach. I can't say I fault them. How angry would you be if a ratchet was dropped on that tile floor or if an oily rag stained something? I am not agreeing with the refusal to render service but I can understand why the shop said no.
HappyGuy is offline   Reply With Quote
Old 08-28-2015, 08:08 PM   #18
silver's Avatar
We will see if you say that when you are hundreds of miles away from home and cannot move your coach!
Old 08-28-2015, 08:11 PM   #19
Where are you know silver? We might be able to get you to a shop that will work on it.
Old 08-30-2015, 08:19 AM   #20
....Is the air to air intercooler ok? That is in front of the rad from the inside closest to the fan and it covers most of the rad. It would have possibly had to go through that first to damage the rad.
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
berkshire
