Old 06-17-2015, 05:19 PM   #11
tmmar's Avatar
I think Phil is referring to Eternabond tape. And as Phil said, send Randy the pictures. Definitely seal it up with something before any water gets in there.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-17-2015, 05:36 PM   #12
Appears water has entered under the transition molding. You need to look very closely to see if you can detect a track or path of water entry. My guess with most all mfrs. this will be a customer maintenance determination. Unless absolutely Nesc. Try not to goop it all up till you have a RVTech look it over and at least give you a cause. I work on this type problem EVERY day. IT is very common to all makes. The larger the RV the more prevalent. These big units twist and flex unbelievably when moving and turning on uneven terrains like driveways. The sealers dry and get very solid and will either crack or break loose from the surface area. We have begun to use the new tapes developed for these areas. The rubber over the adhesive keeps the moisture from leaving the sealer and allows it to flex without breaking open.
hillsdaletc is offline   Reply With Quote
Old 06-17-2015, 05:45 PM   #13
Thanks Tom that is what I was trying to say.
Old 06-17-2015, 06:09 PM   #14
tmmar's Avatar
hillsdaletc,
The OP's coach is a 2014 which means that is probably around 2 years old. I don't think that this type of situation should occur on a coach that young.
Tom and Margaret
Old 06-17-2015, 06:27 PM   #15
I agree it should not happen that soon. But I have discussed sealants with many of the sealant suppliers to the RV industries over the last 35 years and their research on durability is amazing but it keeps coming up as great attempts , but with the sun and weather along with all the movement of the sealed seams a real answer has not been found. Your problem is your seam is up on the roof. It catches the water along the sealed molding and the water of course finds an opening. If the roof surface was wrapped over the side it would have a clear run off of the roof quickly. It's all about appearance.
Old 06-17-2015, 07:16 PM   #16
Campin Cajun's Avatar
X one million what everyone else said and keep us posted on what they tell you.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 06-18-2015, 07:15 AM   #17
Roof issue needs fast repairs
Originally Posted by wmorton46 View Post
During the safety inspection, I was looking at the roof and found the metal strapping holding and sealing the roof to the frame has buckled on each side of the rig in the same spot. Any thoughts/suggestions would be appreciated. See photos.
2014 Berkshire 400QL
2005 Honda Pilot
If it was mine I would not be wasting my time on any forum, you need to contact FR service and get this repaired ASAP. as the what is wrong to many things could have caused this, and unless someone can do a hands on inspection you will never have the full story.
So please contact FR asap and have the repaired as this looks like a big issue.
Sorry for your issues but Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 06-18-2015, 07:48 AM   #18
lgray's Avatar
[ If the roof surface was wrapped over the side it would have a clear run off of the roof quickly. It's all about appearance.[/QUOTE]
Completely agree with this thought. It wil be interesting to see if FR/Berkshire does the right thing here.
lgray is offline   Reply With Quote
Old 06-18-2015, 08:15 AM   #19
Retired Traveler
wmorton46's Avatar
I am working with Mitch Wirt at FR. I talked with him yesterday and he told he was going to review with production and advise today. He said it appears that the screws broke. I went on the roof and found no screw in the opening. Thanks for all the information and I will keep the thread updated.
Walter & Sandra
2014 Berkshire 400QL-60
2017 Shockwave Toy Hauler
2008 2500 Dodge Ram
"Trying to have have fun!"
wmorton46 is offline   Reply With Quote
Old 06-18-2015, 08:20 AM   #20
Retired Traveler
wmorton46's Avatar
Thanks for all information. FR did return my call ad I expect some more information today after they discuss with production. Will keep you updated.
Walter & Sandra
2008 2500 Dodge Ram
berkshire, roo, roof
