06-16-2015, 07:09 PM
Retired Traveler
Berkshire Roof Coming Apart
During the safety inspection, I was looking at the roof and found the metal strapping holding and sealing the roof to the frame has buckled on each side of the rig in the same spot. Any thoughts/suggestions would be appreciated. See photos.
2014 Berkshire 400QL
2005 Honda Pilot
06-17-2015, 08:20 AM
Apple Valley, CA
Berkshire roof coming apart
Hi wmorton46, that's terrible, I can't believe you've had no replies. have you contacted Forest River, did they get back to you? you might add your post to the Berkshire forum they are really good about helping.
Roger & Norma
2014 Berkshire 400QL 360
06-17-2015, 08:41 AM
That needs to go back to the factory, IMO.
I would contact their warranty/repair folks asap before the damage becomes worse.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-17-2015, 08:44 AM
For sure that is not good. I'll be checking mine today. I've not read about that issue on here before ??
Russell
06-17-2015, 08:50 AM
WOW I would fill that with some caulking and contact warranty that shouldn't happen. Keep us posted on what FR says and does. WOW
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
06-17-2015, 10:44 AM
Retired Traveler
Thanks for the replies. Have contacted FR and awaiting a returned call!!
06-17-2015, 11:05 AM
Never Leak RV Roofing
Is the roof soft in that area?
06-17-2015, 11:17 AM
I have a 2014 390 FL. Just checked it. My is sealed good all the way.
Russell
06-17-2015, 02:36 PM
I answered you post where you had it posted earlier. You should get some Berkshire response here.
Your pictures for sure made me go check mine. Mine is a 2014 as yours and I see no problem with mine.
A call to FR is a must for you. A problem occurring on both sides tell me that something rather big is going on.
Good luck. I'm guessing FR will get right on this.
Russell
06-17-2015, 04:50 PM
2005 Honda Pilot
Definitely get a hold of Randy at FR and send him the pictures. I would do everything I could to get it to the factory to have it repaired. No way a dealer would touch it. In the mean time get some of that tape on it. I forget the name someone will jump on here with it. The tape will hold for several months until you can get it fixed permanently.
06-17-2015, 05:19 PM
I think Phil is referring to Eternabond tape. And as Phil said, send Randy the pictures. Definitely seal it up with something before any water gets in there.
Tom and Margaret
2014 Berkshire 390bh-60
06-17-2015, 05:36 PM
Appears water has entered under the transition molding. You need to look very closely to see if you can detect a track or path of water entry. My guess with most all mfrs. this will be a customer maintenance determination. Unless absolutely Nesc. Try not to goop it all up till you have a RVTech look it over and at least give you a cause. I work on this type problem EVERY day. IT is very common to all makes. The larger the RV the more prevalent. These big units twist and flex unbelievably when moving and turning on uneven terrains like driveways. The sealers dry and get very solid and will either crack or break loose from the surface area. We have begun to use the new tapes developed for these areas. The rubber over the adhesive keeps the moisture from leaving the sealer and allows it to flex without breaking open.
06-17-2015, 05:45 PM
Thanks Tom that is what I was trying to say.
06-17-2015, 06:09 PM
hillsdaletc,
The OP's coach is a 2014 which means that is probably around 2 years old. I don't think that this type of situation should occur on a coach that young.
Tom and Margaret
06-17-2015, 06:27 PM
I agree it should not happen that soon. But I have discussed sealants with many of the sealant suppliers to the RV industries over the last 35 years and their research on durability is amazing but it keeps coming up as great attempts , but with the sun and weather along with all the movement of the sealed seams a real answer has not been found. Your problem is your seam is up on the roof. It catches the water along the sealed molding and the water of course finds an opening. If the roof surface was wrapped over the side it would have a clear run off of the roof quickly. It's all about appearance.
06-17-2015, 07:16 PM
X one million what everyone else said and keep us posted on what they tell you.
2013 Berkshire 390BH
06-18-2015, 07:15 AM
Roof issue needs fast repairs
2005 Honda Pilot
If it was mine I would not be wasting my time on any forum, you need to contact FR service and get this repaired ASAP. as the what is wrong to many things could have caused this, and unless someone can do a hands on inspection you will never have the full story.
So please contact FR asap and have the repaired as this looks like a big issue.
Sorry for your issues but Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
06-18-2015, 07:48 AM
[ If the roof surface was wrapped over the side it would have a clear run off of the roof quickly. It's all about appearance.[/QUOTE]
Completely agree with this thought. It wil be interesting to see if FR/Berkshire does the right thing here.
06-18-2015, 08:15 AM
Retired Traveler
I am working with Mitch Wirt at FR. I talked with him yesterday and he told he was going to review with production and advise today. He said it appears that the screws broke. I went on the roof and found no screw in the opening. Thanks for all the information and I will keep the thread updated.
Walter & Sandra
2014 Berkshire 400QL-60
2017 Shockwave Toy Hauler
2008 2500 Dodge Ram
2012 Honda CR-V
"Trying to have have fun!"
06-18-2015, 08:20 AM
Retired Traveler
Thanks for all information. FR did return my call ad I expect some more information today after they discuss with production. Will keep you updated.
Walter & Sandra
2008 2500 Dodge Ram
2012 Honda CR-V
