Old 11-19-2012, 09:26 PM   #11
2011 Berkshire 390BH
Superchief's Avatar
VinceU,
Looking at the installation guide, it does indicated that there is an option to install a circuit breaker in the wire from the battery to the pump: "Step 12 (Pump +12v): Attach a # 4 gauge wire (# 2 gauge if the run is over 12ft.) between the positive +12v terminal on the battery and the common posts on the motor solenoid. This supply may be fused at the source with a 120-amp circuit breaker. This +12v supply must be a dedicated and isolated circuit (not shared with other devices), and must be constant, non- switched +12v." I did look for a circuit breaker in the battery compartment, but could not find one. I will have to see if it is somewhere else or if I missed it. Thanks for the help!
Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 11-19-2012, 09:54 PM   #12
VinceU's Avatar
Originally Posted by Superchief View Post
VinceU,
Craig
Here's the cable you're looking for the big red. Mine wraps up from here to the girder runing front to back. There it bolts to a inline circuit breaker to the battery control center. Its large and red and easy to trace.
Old 11-19-2012, 10:53 PM   #13
Superchief's Avatar
VinceU,
Thanks for the photo (worth a thousand words)! I will see what I can find tomorrow.
Craig
Craig
Old 11-20-2012, 08:20 PM   #14
Superchief's Avatar
To all - Thanks - Problem fixed!!!! I won't bore you with all the things that I spent four hours today trying to do to fix the problem, but just as I was about to give up in frustration, I tried one more thing and it worked! I don't know why exactly it worked, but it did work and I'll take it and run! I will tell you what worked first and then if your interested you can read what didn't work in my situation. When I left yesterday, my coach was in storage, in a ready to travel status with air bags inflated, but jacks extended to within 6 inches of the ground and front slides and jacks would not work or move. When I arrived to day, I found the coach air bags had deflated and the jacks were touching the ground. I figure the air escaped because the jacks were extended. Here is picture of a hydraulic unit similar to mine:
This unit has four override valves, mine has five. What I did in frustration and as a last ditch effort was to take a flat screw driver and turn all of the override screw closed. I then took the two red direction valves (not noted on the diagram) and pulled them out and turn them half a turn to lock them open. I then went in to the Motorhome and turned on the display and tried to retract the jacks. Nothing happen. I went back out and opened the five screw (back to original position) and returned the red directional valves to their original position. I then went in an tried to operate the display key pad and to my amazement I heard the jacks being retracted. I then tried the front two slides and they both worked. Why this worked I can only guess, but I think there was to much air in the system and that was why it didn't respond, so when I closed the override screw and open the red directional valves, it must have broken the air lock. I will stay with that until someone offers a more technical analysis.
So what did not work that I tried:
1-disconnecting the negative terminals on all of the batteries
2-disconnecting all of the electrical connections to the hydraulic unit and the module
3-trying to reset the command display by either pushing all four up or down arrows at the same time and hold them for a period of time.
4- trying to Nil the command display to think everything was level.
5-looking everywhere for a tripped breaker. I did find the breaker in behind the chassis batteries on the left side, but the little ear tag was not out.
Over the four hours I tried the above things many times in various sequences. I also went to the dealer and looked at another 2011 unit with the Service people to see I was looking in the right places and to see what the circuit breaker for the hydraulic unit looked like. They did give me a service sheet for the unit and how to purge the air of it, but that was only applicable if the jacks and slides were retracted. They said if I succeed to let them know how I did it. Will make that visit tomorrow!
Craig
Old 11-20-2012, 08:51 PM   #15
VinceU's Avatar
To all - They said if I succeed to let them know how I did it. Will make that visit tomorrow!
Sounds great Craig, I know whats it like to be high and dry, I had slides out and jacks fully down once also. Was a faulty electronic control cable. My only guess of what you did right: Could be one of the electric valves you manually opened and closed got stuck and you freed it? At least you have this for next time (not)!
Old 11-21-2012, 09:01 AM   #16
tmmar's Avatar
Craig,
Happy to hear that you resolved the problem and, eventhough it took some jockeying around, turned out not to be a major problem.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-30-2012, 07:22 PM   #17
First question
Two Rear slides are electric ... not hydraulic. This is also the reason why slide locks are not required in the rear.
Second
Breaker panel is located on the front right edge of bed. These breakers are responsible for most 120 circuits.
There are a large number of relays that are located in one of the rear compartments on the driver side (I think second from back).
Coach fuses for 12 volt systems are located in driver footwell and front gentset compartment.
Suggestion
Make sure that all batteries (both coach and House) are well charges.
Make sure hydraulic fluid levels are at proper level
lefaivre is offline   Reply With Quote
Old 03-15-2013, 05:48 PM   #18
410 QS 425 2011 Birkshire
I have 2011 410 QS and the front slides will not retract if the jacks are down.
malewis49 is offline   Reply With Quote
Old 03-15-2013, 06:29 PM   #19
Berkshire 390QS
NO3putt's Avatar
Our slides will work with the jacks up or down, but we don't open them unless we are level. Our manal says to level HM before opening slides.
