Old 01-12-2016, 04:01 PM   #11
JTN8's Avatar
Originally Posted by jegstrup View Post
My flush system hasn't worked since the first time I tried it. Pressure builds up in the line then I hear spraying water, the. The water starts running out the top of the storage compartment next to it. I've tried to take panels off to see where this is happening but no luck yet.
But, the flush system just used more water and we already have a full tank of soapy water that would be a good flush.
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
If you take the white panel off on the water pump side of your utility bay, you'll have access to the top of the black tank and the actual black tank flush sprayer. Mine stopped working (my fault, drove the camper with an almost full black tank and it clogged the holes of the sprayer) so I had to remove the sprayer head, soak it in hot water and clean it. Cleared all the little holes out and reinstalled it and works like new. Lesson learned don't travel with the tank over 2/3!!
Jason
Old 01-12-2016, 06:07 PM   #12
I ALWAYS run a LITTLE grey tank water through the sewer hose first to test my connections. Then I close the grey and run the black empty. This lesson comes from my discovering a pin hole leak in my hose while dumping the black. Better to be leaking grey and aborting the tank emptying process than black. Trust me on this!
Moose
2009 FR Berkshire 390BH
jbramhall is offline   Reply With Quote
Old 01-12-2016, 07:09 PM   #13
dan-nickie's Avatar
I think the obvious problem would be too much potential for operator error.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 01-12-2016, 07:14 PM   #14
Ford Idaho's Avatar
I agree with this post.
Old 01-12-2016, 08:08 PM   #15
I never leave the gray valve open since it often results in nasty smells coming into the coach.
Drain the black tank first and then flush the hose with the Grey.
lefaivre is offline   Reply With Quote
Old 01-13-2016, 07:26 AM   #16
JTN8's Avatar
Interesting, I've left my grey valve open on all of the campers I've owned and have never had a smell come in the coach. I would inspect your tank vents on the roof and ensure they are working properly. We usually just do weekend camping with a few longer trips but I lived in my Berk for about a month and a half while on travel for work and never shut the grey valve and never had a smell in the MH.
Jason
Old 01-13-2016, 08:02 AM   #17
AquaMan's Avatar
On my last 5er, I had 3 gray tanks and 2 black. When I was set on my seasonal site for any length of time, I usually left my gray tanks open, but closed them when I left (added some water and tank treatment) just to keep them fresh smelling and keep the traps from evaporating (plugs in sink also). Not sure if that actually helped, but never had a smell problem. As for the black tanks, on seasonal site I usually had all day Sunday to clean up and piddle, so I would empty tanks and then flush/fill/flush a couple times until water was clear and no residual paper product was present. I always set an alarm on my phone when filling tank, so I wouldn't get distracted and forget (came close once ). When moving around and not on seasonal, I would save shower tank for flushing hose. This process may change if in areas where there is a water shortage. Haven't devised a good plan yet for the GT, but with 2 baths and 2 showers, shouldn't be a problem.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-13-2016, 10:19 AM   #18
The traps should keep the smells from the gray tank out.
Iwritecode is offline   Reply With Quote
Old 01-13-2016, 01:08 PM   #19
2014 360 QL
po 185's Avatar
I go every year and stay for 6 mo. at a time at one place.. I drain the black tank and then the gray tank-----once a week. that is when the wife washes---leave the gray tank valve open till she finish , then close it till the next time she wash
2014 360 ql
po 185 is offline   Reply With Quote
Old 01-13-2016, 03:10 PM   #20
CDR USN Ret
Drains and Vents
I used to keep the gray water drains open when hooked to park sewer. At times, I would experience sewer gas odors when out and around my unit. Sometimes I would also pick up sewer gas odors in my toy hauler garage (that's where the washing machine fittings are).
I could solve the garage area odor problem if I was careful to keep the washing machine drain trap charged (sealed with water). Then I realized, that the black and gray water systems are fitted with plumbing vents exiting through the roof, and since I have three gray tanks as well as the black tank, I've got 4 plumbing vents on my roof, and with gray drains open, I am venting the parks sewer gasses through my unit's gray vents - 3 of them.
As soon as I started closing the gray drain valves, and I installed a twist-on gate valve at the sewer hose connection (to isolate the washing machine drain), I've had none of those odor problems - and have had no need of tank deodorizer. Sure, the onboard tanks are still vented, but apparently the onboard black gray tanks do not produce enough sewer gas to be noticeable.
We have been full-timing for over a year now, and this strategy has been working for 10 months.
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
black, tank
