Old 01-12-2016, 11:58 AM   #1
jegstrup's Avatar
Black & gray tanks
Maybe I'm overlooking an obvious, but why wouldn't an RV manufacturer design an RV where the gray water flushes thru the black water tank.
If the gray tank sat above the black water, you could get a much better black flush.
Please feel free to point out any obvious issues I may have overlooked.
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
jegstrup is offline   Reply With Quote
Old 01-12-2016, 12:03 PM   #2
accumack's Avatar
Probably if the black water tank overflowed it would backup into the gray. And add complexity.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 01-12-2016, 12:05 PM   #3
JTN8's Avatar
I always keep my grey valve open when camping with full hookups and only pull the black when it's full. If the grey ran through the black, I'd be dumping much more often. I will say that with the black tank flush installed on our Berks, it cleans the tank really good! I use a clear sewer connector and flush the tank for a good 20 minutes or so and the water comes out crystal clear.
Jason
Old 01-12-2016, 12:06 PM   #4
caper's Avatar
I have to drain the gray twice before the black needs to be drained.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-12-2016, 12:10 PM   #5
jegstrup's Avatar
A good reason for a setup like this
Old 01-12-2016, 12:23 PM   #6
I think I understand what you are wanting and I agree. What I do is when my gray is full I dump my BT. As it finishes and the hose is still full I pull the gray and count to ten. This pushes a good amount of gray water into the BT I then shut the gray off and flush the BT. Then empty the gray. It seems like all that gray water would be a good way to flush the BT. This only works if I remember to close the GT so it fills up as I do leave the gray open all the time.
Old 01-12-2016, 12:39 PM   #7
jegstrup's Avatar
Phil,
I do the same thing, except leaving the gray tank open. I'm currently wintering in Colorado so that wouldn't work here lol.
Old 01-12-2016, 01:16 PM   #8
BamaBob's Avatar
Another reason has to do with plumbing mechanics. It is difficult to put the gray tank "above" the black tank - they are both seated on the frame at the same level, so the natural exit point for each tank would be the low point.
All Berks have a excellent Black tank flush system and, if you are practicing the GEO method you should have zero problems with your black tank--even when using comfy 2 ply household toilet paper (like Northern or Charmin) but NOT moist wipes (those need to go in the trash).
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 01-12-2016, 01:38 PM   #9
jegstrup's Avatar
My flush system hasn't worked since the first time I tried it. Pressure builds up in the line then I hear spraying water, the. The water starts running out the top of the storage compartment next to it. I've tried to take panels off to see where this is happening but no luck yet.
But, the flush system just used more water and we already have a full tank of soapy water that would be a good flush.
Old 01-12-2016, 03:27 PM   #10
BamaBob's Avatar
Something is *NOT* right with your black tank flush. But first, to clarify, when you turn on the black tank rinse your black tank valve is *open* correct? If you keep that baby closed "bad things happen™"
Don't ask me how I know....
black, tank
