Usually there is a small vent window just opposite the "JOHN" room that should be open when running the bath vent fan or the kitchen vent fan over the stove. The window nearest the stove should be open about 1-2" when running the stove
vent fan.
RV's are so air tight when all the windows are closed that when running a vent fan where in bath or kitchen air has to be drawn from somewhere.
Water in drain traps prevents air from being pulled from the drains. But for
the "WATER CLOSET" (commode) has a straight drop to the black tank, therefore when you step on flush valve with vent running for bath or kitchen foul air will be drawn up through the toilet.
My RV has a small oval window just across the hall from the toilet I open about 1-2" and leave open.
