Originally Posted by herk7769
Like this one.
They work great and I put another one in my gray tank for soap and hair removal.
The end spins and tumbles shooting the water stream all over the tank walls and sensors.
Herk7769 Lou, Laura and Bella:
I think it is the unit at
http://www.amazon.com/Camco-40126-To.../dp/B000BUU5TU Available from Walmart for $20. If so, this unit did not get very good reviews, as far as efficacy of operation is concerned.
Also, specific to the Berkshire, does this replace the factory-installed unit, and if so, I have not read here that anyone has been successful in accessing the factory unit for service or repair - how did you do it, or is it installed some other way?
And Speedmerchant:
I don't plan on buying the nozzle - just looking at one to see how to service it (run piano wire from the outside connection to clean the nozzle orifices?). The original one can't be accessed, as far as I know. Also, I suspect it's a design fault, and replacement wouldn't do much good.
