Old 05-30-2013, 10:27 AM   #1
EJM4's Avatar
Black Water Flush
I'm having trouble with my black water flush. No water will enter the tank. Any ideas?
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 05-30-2013, 10:28 AM   #2
TURBS's Avatar
Sounds like maybe the check valve may be stuck.
Try poking it with a tent stake or something of the sort to dislodge it.
Turbs
Old 05-30-2013, 10:35 AM   #3
Herk7769's Avatar
Turbs
Turbs, I think he means the TurboFlush inlet. That valve is inside the camper. Mine is located under the vanity.
There could be trash in the sprayer itself. This could involve removing the sprayer from the tank wall and removing the paper or crud that has blocked the jet.
HAM CALLSIGN - KC3FFW
Old 05-30-2013, 10:37 AM   #4
EJM4's Avatar
The coach has the San T Flush system. I looked under the sink last evening and did not see anything like your picture.
Earl
Old 05-30-2013, 10:42 AM   #5
TURBS's Avatar
My bad....
Mine is located in the water station outside.
Old 05-30-2013, 10:46 AM   #6
Herk7769's Avatar
I don't know anything about that system (sorry).
However there has to be a vacuum break (check valve) somewhere to prevent reverse suction/ siphoning of black water overboard.
Old 05-30-2013, 12:53 PM   #7
Your first try to use it this year?? I found on my old Dutch Star that the small spray holes could get plugged when the "stuff" dries over winter. If I kept pressure on it for an hour or two eventually it would unplug itself.
Boowho??
boowho is offline   Reply With Quote
Old 05-30-2013, 08:52 PM   #8
EJM4's Avatar
We're headed out tomorrow for the weekend. I filled the black tank this evening and will dump it tomorrow night, hopefully there is just something stuck on it.
Earl
Old 05-31-2013, 09:03 PM   #9
EJM4's Avatar
UPDATE | filling the tank and letting it sit over night in addition to adding ice while we drove this afternoon did not solve the problem. I suppose something is wrong with the check valve.
Earl
Old 06-29-2013, 09:55 PM   #10
edgewant's Avatar
EJM4,
Did you ever figure out this problem? On my 2013 water will enter into the black tank from the flush line but there seems to be back pressure. When I remove the hose from the flush line about a quart of water will drain back out of that line.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
