Old 06-06-2019, 09:24 AM   #1
jmgllt's Avatar
Black Water Tank flush check valve
Other than replacing the whole thing is there something I can check to see if itís stuck closed and free it up?
jmgllt is offline   Reply With Quote
Old 06-06-2019, 10:25 AM   #2
bubbles's Avatar
Here are 2 versions and you may have the black one. The clear one shows the internals. Water comes in from the bottom and pushes the disc up to seal off the vent to ambient and at the same time water pressure is applied to the horizontal output through a spring loaded check valve (ball) to the tank. If you pull out your valve these pictures should allow you to check the operation with either water or air. This may help.
Name:	vacuum-breaker black.jpg
ID:	206565   Click image for larger version
Old 06-06-2019, 05:18 PM   #3
Dragonship Captain
Oscarvan's Avatar
I know there's an anti syphon valve in the line.... not sure if there's a check valve (one way valve) anywhere.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 06-06-2019, 08:26 PM   #4
bubbles's Avatar
They are one and the same. It's a vacuum breaker/check valve. A dual purpose valve as shown in previous post.
Old 06-06-2019, 10:43 PM   #5
Dragonship Captain
Oscarvan's Avatar
Ah.... now it makes sense.
Old 08-10-2019, 03:22 PM   #6
Originally Posted by gordonsick View Post
.....I do notice that disconnecting the hose to my black water flush does result in a bunch of clean water coming back out of the connection....
The same happens with my black tank flush. Anyone know if a bunch of water should come back out of the black tank flush connection when the hose is disconnected??
2017 Berkshire XL 40A & 2017 Ford Focus SE
I Built and Fly - Van's Aircraft RV-12
Ham Radio - W9EAA
MartyQ is offline   Reply With Quote
Old 08-11-2019, 05:23 AM   #7
jeff64's Avatar
The btf valve is at the high point, water runs downhill both directions once the pressure/vacuum releases. So yes ,water runs out of the connector
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 08-11-2019, 06:10 AM   #8
I get a lot of water forcibly. Definitely under pressure.
Ham Radio - W9EAA
Old 08-11-2019, 07:50 AM   #9
Canadian Member
I recently replaced mine with a brass Watts LF288A. The plastic one was leaking and there are lots of stories here about them breaking. You can also just replace it with a plastic 90 degree bend and use a backflow preventer made for a garden hose spigot. If you remove it, please use an equivalent somewhere in the water line feeding the flusher.
MartyQ, sometimes the factory installs them backwards and water won’t flow through them. That may be your issue. On my 2 trailers that have had a black tank flusher, you can hear the water spraying into the tank when the tank is empty.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
black, black water, check, flush, tank, valve, water, water tank
