Old 10-24-2014, 05:17 PM   #1
JTN8's Avatar
Blank tank flush
Anyone ever had their tank flush nozzle clogged??? I hooked up the water hose and hear nothing! Usually hear the water spraying quite loud...
Jason
Old 10-24-2014, 05:32 PM   #2
tmmar's Avatar
Jason,
Sounds like the back flow valve on the flush is clogged or broken. I believe that this issue has been posted about before. Should be easy to replace.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 10-24-2014, 05:47 PM   #3
Jason, we had the very same thing and they checked the check valve, we were at the rally and they replaced it but it still didn't work and they found it was the actual sprayer at the tank that was clogged and they said it was corrosion but we had only taken possession of the MH in April and this was August and our campground in the summer is on a well with hard water. Mike runs a water softener but he didn't used to for the black rinse now he does so another option to look at!
Sylvie is offline   Reply With Quote
Old 10-24-2014, 06:44 PM   #4
Campin Cajun's Avatar
I had the same thing happen, water barely coming out. I removed the sprayer and reamed out the holes to a bigger size. I used a regular drill bit, can't remember the size bit, but all I did was use a bit one size bigger than the holes. It's very easy to remove, drill out and replace.
One tip if you decide to do it. Once I had the sprayer out I hooked up to water to check how much water came out. Then once drilled I sprayed again and it was much more water coming out.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-24-2014, 07:48 PM   #5
Mmnsc's Avatar
I had the same issue this past summer. I left the hose connected to the black water flush with the water turned on The water was at full pressure as coming from the faucet (no pressure reducer). After about 1 1/2 hour I heard the water to start running through the flush tube. It eventually totally cleared and and has not given me any problems the rest of the summer. Have you tried to just give it time under pressure?
Mmnsc is offline   Reply With Quote
Old 10-24-2014, 08:13 PM   #6
Taranwanderer's Avatar
Just a semi related point here--don't forget to winterize those black tank flushers. I would have totally neglected that if someone here hadn't pointed it out.
Now back to your regularly scheduled thread...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 10-24-2014, 08:21 PM   #7
JTN8's Avatar
Thanks to all for the reply!! How do I get to the nozzle to check it or remove it for those that have cleaned it?
Jadon
Old 10-24-2014, 08:22 PM   #8
JTN8's Avatar
Jason!! Damn auto correct!! Lol
Old 10-25-2014, 07:20 AM   #9
Jason, on the PS side in the compartment where the water pump is located. The black tank sits above the FW tank. There is a panel that needs to be removed, mine had three screws holding it. Once you remove that panel you will see the flusher. I believe it has 4 screws holding it to the tank. Back those out then simply remove the nozzle. It has some black silicone type stuff as a seal. I just used some clear silicone when I replaced mine. It's a 30 minute job.
Old 10-25-2014, 11:56 AM   #10
JTN8's Avatar
Thanks for the info
Jason
tank
