Old 02-18-2015, 09:23 PM   #1
dan-nickie's Avatar
Budget Berkshire Speaker Upgrade
I finally got around to upgrading my 2014 Berkshire RB from those little 2 inch speakers and will try to show what I did here.
First of all, do you guys know how to set the bass, treble and balance on the JRV212 radio? I didn't know, but learned in the process. It is an important part of getting your sound right. Just 'press and hold' the 'Audio' button and a new menu appears.
I wanted to get an acceptable sound without a complicated and expensive install of amplifiers and crossovers.
To replace the little 2 inch speakers, I chose some Kicker 6 Inch Coaxial speakers with power handling of up to 65 watts. Some other brand might be just as good. The important thing was I did NOT want some high priced, high performance speakers that were going to require a lot of power as the Jensen radio puts out about only 40 watts per channel. I got them on Amazon http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
After looking at the ceiling where they would mount, it did not seem that cutting holes in the ceiling for larger speakers was an option. So I got these spacers from Frys Electronics. Two (2) of these needed for each speaker for a total of 2 inch depth.
I painted them white to kind of match the ceiling.
Here they are mounted and connected in the Berkshire.
Many people may be very satisfied at this point as it sounds much better than the stock 2 inch speakers once the bass and treble are adjusted, but I like a little more low end in my music.
Next up was to add a Sub-Woofer to pump up the bass.
I wanted something that would fit through the removable dash panel and sit on the floor out of sight under the dash. After much measuring and remeasuring the floor space and dash panel opening, I chose this PowerBass BTA8 also from Amazon Amazon.com : Powerbass BTA8 Single 8-Inch 150W Amp Enclosure : Vehicle Subwoofer Systems : Car Electronics
A crossover and 150 watt amp are built into the sub box, so nothing else is required to drive it.
To get the Sub in through the dash panel opening was a chore. Had to temporarily remove some heater hoses, the radio as well as the radio chassis.
But it did fit just fine.
Now we have music the way we like it.
I still need to adjust the Sub to get it just right, but we have clear vocals and musical instruments and just enough low end thump to produce music close to the way it was recorded and meant to be heard.
I tried to record something that I could link to for demonstration, but it seems a cell phone does not do a good job of that.
Cheers, Dan
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 02-18-2015, 09:41 PM   #2
Mojojojo's Avatar
Looks good unfortunately now I got another mod to do
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 02-19-2015, 01:54 AM   #3
Dan,
Great mod and now I have another mod I need to do. In my 2011 390BH I have 4 speakers in the ceiling up front. I'm assuming 2 are for the stereo and 2 are for the entertainment surround sound. By the pictures it doesn't look like yours has this. Can you confirm. If it did have four speakers up front how did you wire the speakers? Thanks in advance for your help.
-David
trekdave42 is offline   Reply With Quote
Old 02-19-2015, 06:42 AM   #4
Fulltime in our Berkshire
KennyGolub's Avatar
Very nice. Thanks for the detailed explanation !
KennyGolub is offline   Reply With Quote
Old 02-19-2015, 07:19 AM   #5
dan-nickie's Avatar
Originally Posted by trekdave42 View Post
Dan,
-David
David, the 2014 only has 2 small ceiling speakers up in the cab area wired to the dash radio.
Dan
Old 02-19-2015, 08:33 AM   #6
Campin Cajun's Avatar
Nice mod Dan, I agree, those little 2" speakers are not good at all.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 02-19-2015, 10:19 AM   #7
dan-nickie's Avatar
The 2 inch speakers were useless to us. Neither me or DW could stand it for more than a few seconds. Just made us want to scream. :-)
Dan
Old 02-19-2015, 02:10 PM   #8
The stock small speakers sound like on old pocket am radio. FR could have done better.
uralman is offline   Reply With Quote
Old 02-19-2015, 06:35 PM   #9
camaraderie's Avatar
Nice job on the dual spacers Dan. There are lots of good 6.5" speakers that would work well with that set up with different tonal balance for different tastes that don't require a lot of power and would work well with your spacers. Thanks.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is online now   Reply With Quote
Old 02-19-2015, 06:57 PM   #10
gasman94's Avatar
Looks great Dan. See that you've gotten that project done. Looks great. It's great to have some good sound up front.
Rich
gasman94 is offline   Reply With Quote
berkshire, upgrade
