Old 08-09-2014, 02:53 PM   #1
Kelsma03's Avatar
Bunkhouse slide problem
We are starting week three of a four week trip and when we pulled our slide out nj the morning, heard a loud crack and upon inspection see that the interior bracket that holds the slide wires has pulled off the sidewall. (See picture) it doesn't look like it was anchored very secretly in the first place. Anyone have something similar happen? The mechanism looks fine and all wires attached. We were able to pull the slide in the rest of the way so we could drive. Wondering if we need to keep slide in for the rest of the trip (ugh!). Already made appointment to drop it off at dealers on the way home for repair. Click image for larger version
Name:	ImageUploadedByForest River Forums1407613964.855643.jpg
Ed and Jaime, 3 kids, 2 greyhounds
2014 Berkshire 400BH
TOAD: 2002 Ford Explorer
Kelsma03 is offline   Reply With Quote
Old 08-09-2014, 03:16 PM   #2
What year Berkshire is that. Can you get the screws bak in place? It looks like something got hung up and it just pulled the bracket off the wall. Not sure if I would open that slide until I found what was causing it to bind like that.
Old 08-09-2014, 03:24 PM   #3
Campin Cajun's Avatar
A few of us BH owners have had problems with the bunk slide, I don't remember reading about this problem happening before though, most have been the motor itself going out or the motor shaft breaking. I would not attempt to open that slide again. Those cables work both ways to open and close the slide. This could be an easy fix if you can get to it and re secure it to the wall.
2013 Berkshire 390 BH
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 08-09-2014, 04:25 PM   #4
Kelsma03's Avatar
It's a 2014. It does look like we could get it back in place, just not sure how to get in there. It's pretty narrow even with slides pulled in.
Old 08-09-2014, 05:30 PM   #5
ernest917's Avatar
No dealers close to where you are now???? I'd want it fixed ASAP....
ernest917 is offline   Reply With Quote
Old 08-09-2014, 05:31 PM   #6
Kelsma03's Avatar
We were close to our original dealer wen it happened but they couldn't fix it today. Were heading to another campground and will try to fix it ourselves or call coach net.
Old 08-09-2014, 05:34 PM   #7
ernest917's Avatar
What a bummer.... Good luck buddy....
Old 08-10-2014, 07:46 PM   #8
Keep us posted, Good Luck!!
CT Camper is offline   Reply With Quote
Old 08-10-2014, 08:55 PM   #9
Kelsma03's Avatar
We tried to move it a little today (husband needed to get some underwear) and it looks to be moving crooked. So we are leaving it alone and finishing our trip with it in. We can manage. We have some other things that need fixed so this is hopefully the only major problem.
All part of life on the road!
Old 08-10-2014, 10:22 PM   #10
I'm just into a 15 400bh.. There is another pos about a slide doing same thing. A friend also purchased a new 15 and today had he same issue. It's def a issue.
Steve.heicklen is offline   Reply With Quote
Old 08-11-2014, 07:59 AM   #11
tmmar's Avatar
Yes, there is an earlier post about the same thing happening. Not sure why this happens but it definitely needs to go to a dealer for repair.
Tom and Margaret
2014 Berkshire 390bh-60
bunkhouse, slide
