Old 05-24-2018, 07:12 PM   #1
Buzzing thing
Guys,
This device in the electrical bay under the driver seat of my 2009 Berk is running incessantly and causing a buzzing sound. Do you know what it is?Click image for larger version
ID:	173225Click image for larger version
Moose
2009 FR Berkshire 390BH
jbramhall is offline   Reply With Quote
Old 05-24-2018, 07:27 PM   #2
fonzie's Avatar
See post #3
coach air conditioner not working
Fonzie
Old 05-24-2018, 08:54 PM   #3
So. Vacuum pump for the dash AC? Mine seems to be stuck in the on position, as it runs constantly without regard for climate control setting. Is there some kind of control unit or brain for the thing?
Any idea if this is a common part, or do I have to work with FR?
Thanks for any insights!
Moose
Old 05-25-2018, 01:42 PM   #4
Berkshire 390QS
NO3putt's Avatar
It is a common part and you might find it at an anti parts store. Skip
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
Old 05-29-2018, 08:47 AM   #5
Dijoeboss's Avatar
If it's running all the time, there could be a vacuum leak in the system some where. These typically have a shut off built into them once the vacuum desired is reached, if there's a leak somewhere, it can't pull a vacuum and so it constantly runs. Check the vacuum hoses, connections etc.
Dijoeboss is offline   Reply With Quote
Old 05-29-2018, 09:02 AM   #6
I do have a slow AC refrigerant leak. Would that cause this issue if the refrigerant has leaked out completely over the winter?
Moose
Old 05-30-2018, 05:56 AM   #7
the Freon is a closed loop system not related to the vacuum pump which opens and closes dampers to direct the air to different vents. (floor, dash, defrost)
2012 390BH
dave-g is offline   Reply With Quote
