Old 09-09-2018, 02:14 PM   #1
ernest917's Avatar
By-passing “Water-fill” and going directly into tank
Anyone made an attachment that will allow u to fill ur freshwater tank “without” using the fill in the water compartment?????
I’m thinking it would be really simple to make a fitting that would screw onto the fitting shown in the above picture.... put a female hose fitting on the opposite end and u should be able to shoot water directly into the tank....
This could be used in an emergency situation when ur on the road and suddenly ur check-valve on the fill fitting stops working..... AND no one near you has a replacement available....
Think I’m gonna make one when I get close to a Lowe’s or Home Depot so I can get the materials.....
ernest917 is online now   Reply With Quote
Old 09-09-2018, 03:19 PM   #2
Dragonship Captain
Oscarvan's Avatar
Why don't you put a 3way valve in that line with the female hose connector on the T.... That way you don't lose the vent.
That said, not sure I need this.....The fill on the other side does the same thing... just a little further away.....
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 09-09-2018, 10:34 PM   #3
ernest917's Avatar
Oscarvan....
Check out my third paragraph.... that explains why I’m looking at an alternate method to fill the tank.....
Old 09-09-2018, 10:41 PM   #4
Dragonship Captain
Oscarvan's Avatar
Originally Posted by ernest917 View Post
Oscarvan....
Gotcha....
Old 09-17-2018, 04:10 PM   #5
ernest917's Avatar
No worry...., my fix on main water fill hose did the job.... fresh water tank now full..... yea!!!!
Old 09-20-2018, 04:07 PM   #6
Dragonship Captain
Oscarvan's Avatar
Water good. Congrats on another successful fix without it sitting in a dealer parking lot for 3 weeks and paying them $500 to fix it, and break something else.
Old 09-22-2018, 09:37 PM   #7
I did the mod to use my water pump to pump the water from jerry cans in water tank. Pictures in my post from last month:
A few mods...
Alex and Valerie
2014 Berkshire 400BH
AlexG is offline   Reply With Quote
tank, water
