Old 06-03-2011, 05:33 PM   #1
Cable TV
Can someone please explain to me how to get the cable TV to work? I plugged the cable into the ped at the camp ground and had the TV do a search and it found some stations but they were fuzzy and looked to be just local stations. Does something need to be rewired? Will both the bedroom and the main TV work on cable?
Any help would be great...
csichoice is offline   Reply With Quote
Old 06-03-2011, 05:36 PM   #2
Sorry I forgo to mention I have a Berkshire 390 BH.
Old 06-03-2011, 05:39 PM   #3
Make sure your antenna amp is off. Go into the settings for the TV, usually under channel. Make sure it is set to CABLE not antenna. Re scan and see what happens.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 06-03-2011, 06:09 PM   #4
tmmar's Avatar
There is a connection point in the electrical compartment that one end of the cable is connected to and the other end goes to the pedestal. In the cabinet under the tv, there is an amplifier that is used for the roof antenna. That should be off. Go into the setup menu for the tv and do a station scan for cable not a station scan for antenna. You should then be fine. Both the living room and bedroom tv's should work off the cable. I just had a situation this past weekend. I went through the setup and about half the stations were very snowy. When I asked at the office, they said that thery were not having a problem. There was no one in the site next to me so I hooked up the cable to the pedestal on the other site and the picture was crystal clear. There was some sort of problem with my cable hook up.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 06-03-2011, 06:42 PM   #5
Villa Estate 392FLFB
The_Stuff's Avatar
sometimes the antenna and the park cable are 2 different connections on the wall to the tv.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 06-04-2011, 07:14 AM   #6
Had the same problem...
Follow tmmar's instructions. The amplifier switch is a small black wall switch on the right. Turn it off and you should be fine.
BamaCorner is offline   Reply With Quote
