Old 05-22-2015, 10:26 AM   #11
Crockett's Avatar
Im assuming this has a slide cover? You would probably see staining at the ceiling duct if water was coming in the AC. Investigate for the slightest traces there.
Crockett is offline   Reply With Quote
Old 05-22-2015, 10:34 AM   #12
2011 Berkshire 390BH-60
TaterColo's Avatar
Yes it does have a slide cover. There is no staining of the ceiling at all.
TaterColo is offline   Reply With Quote
Old 05-22-2015, 11:42 AM   #13
edgewant's Avatar
My 390RB has a window in that slide just above the chest of drawers. I would check the window and look at the edges of the slide to make sure its not leaking into the window and then down around the dressing area of the slide.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 05-22-2015, 01:31 PM   #14
Are you storing your Berkshire indoors or out? If outside, is your storage space level? I've got a 2015 Charleston that has been tested watertight (at the factory and at the truck wash), but if I park it off-level I get a leak into the living room.
ckabrahamson is offline   Reply With Quote
Old 05-22-2015, 01:45 PM   #15
I had the same problem on a closet slide never found the leak had to trade it in??
HOPE YOU POST THE FIX!!!
GTONY2
gtony2 is offline   Reply With Quote
Old 05-22-2015, 02:05 PM   #16
Berkshire 390QS
NO3putt's Avatar
Had water coming in on drivers window, ran a bead of sealant and solved the problem.
NO3putt is online now   Reply With Quote
Old 05-22-2015, 02:16 PM   #17
TaterColo's Avatar
Only the carpet under the slide is damp. How is it coming in under the slide? Click image for larger version
Name:	ImageUploadedByForest River Forums1432322091.069159.jpg
ID:	77712Click image for larger version
Name:	ImageUploadedByForest River Forums1432322178.793409.jpg
Old 05-22-2015, 02:25 PM   #18
TaterColo's Avatar
And I do store it outside on fairly level ground.
Old 05-22-2015, 02:38 PM   #19
dan-nickie's Avatar
Originally Posted by TaterColo View Post
Only the carpet under the slide is damp. How is it coming in under the slide? Attachment 77713
Are there any gaskets/rubber seals on the side of the slides?
I can't see any.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-22-2015, 02:51 PM   #20
Had the same issue. The bottom of the slide had a fabric on it and was "wicking" the water into the coach. Dealer installed a plastic bottom on the slide and no more issues.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
leak, water
