Old 05-22-2015, 02:58 PM   #21
2011 Berkshire 390BH-60
TaterColo's Avatar
Did they remove the slide or just put plastic with it slid out?
TaterColo is offline   Reply With Quote
Old 05-22-2015, 03:04 PM   #22
TaterColo's Avatar
Name:	ImageUploadedByForest River Forums1432324997.638238.jpg
ID:	77717Click image for larger version
Name:	ImageUploadedByForest River Forums1432325018.158352.jpg
ID:	77718Click image for larger version
Name:	ImageUploadedByForest River Forums1432325037.493588.jpg
Old 05-22-2015, 03:19 PM   #23
Leak
Do you have slide out covers? If not look at the seal area closely and see if you may have closed some debris into the seal area last time out. Debris (leaves etc.) will compress against the coach seal and hold it partially away from the roof surface.
hillsdaletc is offline   Reply With Quote
Old 05-22-2015, 03:22 PM   #24
leak
From viewing the picture of the bottom of the slide it looks like the lower sweep seal is missing. Water can enter this area from tire spray along the side of the coach in the rain.
Old 05-22-2015, 03:32 PM   #25
TaterColo's Avatar
Name:	ImageUploadedByForest River Forums1432326610.829137.jpg
ID:	77720Click image for larger version
Name:	ImageUploadedByForest River Forums1432326649.099848.jpg
I pulled that seal out on the side to show you. Yes the bottom does not have that.
Like on the kitchen slide here.
Name:	ImageUploadedByForest River Forums1432326748.944039.jpg
Old 05-22-2015, 03:58 PM   #26
mark0224's Avatar
I don't have any water problem but neither of my slides have wiper going across the bottom of the slide. Was contemplating adding a wiper seal there to better seal the slides.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 05-22-2015, 05:35 PM   #27
The bottom of your slide looks the same as mine did. The 1/8 thick piece of plastic covered the whole slide bottom. They just jammed it under the slide, it was fastened all around the edge.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 05-22-2015, 05:49 PM   #28
Superchief's Avatar
On mine that little square piece on the cable is glued to the seal on the coach side.
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 05-22-2015, 07:24 PM   #29
Campin Cajun's Avatar
Were the slides open during the recent rains? If so it could be from water leaking down the side walls of the slide and getting to that lower lip then going inside.
I have that same black mark on my carpet that you have in the first picture. I can't figure out where it comes from.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 05-22-2015, 07:49 PM   #30
Send a message via MSN to Tiggerdad
Darco wrap on bottom. Sorry excuse for a material. It is not water proof and has a problem with tearing on 5er slides. Prime Time denies that it is a problem. It will wick water and rot the bottom. Keep a close eye on the edges.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
leak, water
