Old 05-24-2015, 03:46 PM   #61
2011 Berkshire 390BH-60
TaterColo's Avatar
The plywood seems to be working like a sponge. Again no watermarks on ceiling or walls. No strange water stains on the outside of the coach either.
TaterColo is offline   Reply With Quote
Old 05-24-2015, 04:07 PM   #62
TaterColo's Avatar
We got home and I got my ladder out. Again looked at the roof and everything seems sealed. With the slide out I looked under the slide cover at the top of the slide. All looks normal. On the 2nd pic you can see where the paint has been rubbed telling me that the rubber seal on the slide is tight against the coach. The 3rd picture is showing you the dripping water from one of the screws.
Name:	ImageUploadedByForest River Forums1432501470.141553.jpg
Name:	ImageUploadedByForest River Forums1432501498.144905.jpg
Name:	ImageUploadedByForest River Forums1432501612.860650.jpg
Old 05-24-2015, 04:39 PM   #63
The screw in front of the drip is rusted and has had water running in it also. At least it looks that way. I had a leak in the skylight and would have never guessed it from the caulking but I put a fresh coat on it and no more leak.
Old 05-24-2015, 04:41 PM   #64
TaterColo's Avatar
I opened the emergency window. (Just to let everybody know it's hinged at the top - Murphey's law dictates the window would fall out and break lol!!!).
I can understand water getting in but the wood is so damp there would seem to be a lot of water. And this is a horizontal surface. It would have to be a driving rain to get in this much water. However this seems like the only place. I'm baffled. But it's getting in somewhere.
Name:	ImageUploadedByForest River Forums1432502747.423281.jpg
Name:	ImageUploadedByForest River Forums1432502767.926129.jpg
ID:	77919Click image for larger version
Name:	ImageUploadedByForest River Forums1432503367.637637.jpg
ID:	77923Click image for larger version
Name:	ImageUploadedByForest River Forums1432503393.758052.jpg
Old 05-24-2015, 05:22 PM   #65
dan-nickie's Avatar
I still think it is the window leaking.
It could not be a bottom of slide leak and make it's way up to the window.
The window is the highest point you have identified water/wetness.
I had a window leak on my last class C around the window rubber trim one rainy day.
It did not even look like it from the outside, but I was surprised how much water came in.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-24-2015, 08:18 PM   #66
Campin Cajun's Avatar
I'm going with Phil, I had a water in the top cabinet above the driver's seat. I went up on the roof a few times to check the caulking but it always looked in tact. Until onetime when I got down on my hands and knees up there and noticed a very small section where the caulking lifted off the roof. It was only about an inch long but it was in an area that pools a little water. I repaired the caulk and it never leaked again.
Above that bunk slide on the roof there is a vent for the frig, Water pools there also, not much water but enough to cause a leak. I would check that area.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 05-24-2015, 08:30 PM   #67
Herk7769's Avatar
Originally Posted by lrob View Post
I don't own a Berkshire but a Legacy and had water leaking into my bedroom. Called the factory and the talked to the manufacturing floor. It turns out that the bolts that attach the roof air conditioner were not tighten down completely during installation. When it rained, the water would seep through this gap and drain into the ceiling vents and drip into the bedroom. Not sure if this is your problem but my slides were in as well and this has been fixed and problem solved. Hope this helps.
I had this same problem on my 5th wheel air conditioner. The AC was not properly torqued to the roof and after a few months started leaking. The seal had to be replaced (NOT RE-TORQUED) as dirt gets under the foam seal surface and it will no longer seal properly.
A properly torqued unit will have the yellow tabs just touch the roof (evenly at all tabs). If they are crushed or not touching the roof you will eventually get a leaker.
ID:	77933   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 05-24-2015, 09:15 PM   #68
TaterColo's Avatar
Hopefully the dealer along with FR can figure it out. Again - thank you to everyone who chimed in on this. It's been very helpful.
Todd.
Old 05-24-2015, 09:24 PM   #69
I know you are not close to FR but if you have a trip planed that way FR can pressurize the MH and they go around it with some kind of spray. If it is leaking it will show up. They did mine and find a problem above the drivers seat that I wasn't aware of.
Old 05-24-2015, 11:36 PM   #70
TaterColo's Avatar
Interesting. I didn't know they could do that. I'm temporally un-employed so if the dealer can't figure it out - a trip to FR may be in my future.
leak, water
