Old 03-26-2016, 06:57 AM   #81
dan-nickie's Avatar
Originally Posted by TaterColo View Post
Water leak solved-hopefully. The dealer said the lower trim piece on the bunk side was the problem. The water would run down the slide and get between the trim piece and the slide and then in the coach. I said it seemed like a manufacture issue. They called FR and FR said it was a maintenance issue.????
This is the trim piece I'm talking about.
Attachment 102737
Thanks for the feedback. Did they explain what type of Maintenance should be done on it?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 03-26-2016, 09:29 AM   #82
Can anyone explain where the water is leaking from.
The slide gasket on that wardrobe slide is inside and under the bottom of the slide. The gasket on my 2014 BH had broken free to the point it was flapping around and getting caught up in the rollers. I could see daylight under the dresser. I called Andy Thompson, he sent me a new exterior gasket which I installed and it solved the problem.
IMHO that is where your problem is, moisture getting past the gasket.
Paul
2015 XL 40QL-60
2015 Jeep Wrangler Unltd. Sahara
Paulie Boy is offline   Reply With Quote
leak, water
