Old 05-21-2015, 08:11 PM   #1
2011 Berkshire 390BH-60
TaterColo's Avatar
Can anyone explain where the water is leaking from.
On my 2013 360BH when I put the bed slide and the wardrobe slide out there is a mark on the carpet. Today when I picked it up from storage I put the slides out and the carpet was damp. We have been getting a lot of rain lately. I'm wondering how the water is getting in? The slides are completely closed. See the pics.
Thanks in advance!
Name:	ImageUploadedByForest River Forums1432257044.051917.jpg
ID:	77659Click image for larger version
Name:	ImageUploadedByForest River Forums1432257056.769343.jpg
ID:	77660Click image for larger version
Name:	ImageUploadedByForest River Forums1432257070.104574.jpg
TaterColo is offline   Reply With Quote
Old 05-21-2015, 08:19 PM   #2
My bet it is coming in from the top of the slide where it meets the camper. The water is leading in! Follows the roof down to the interior front. At this point it leaks to either side and stains the carpet.
just a guess.
2015 Sandpiper 30IOK
2014 Ram 6.7 CC DRW
2006 Charger RT
X96mnn is offline   Reply With Quote
Old 05-21-2015, 08:34 PM   #3
vinmaker's Avatar
OMG. That cannot be good at all. I am not sure where it is coming in from but you definitely need to fix it asap. I agree with the above posted. The most likely place is the slide seals.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-21-2015, 09:21 PM   #4
lrob's Avatar
I don't own a Berkshire but a Legacy and had water leaking into my bedroom. Called the factory and the talked to the manufacturing floor. It turns out that the bolts that attach the roof air conditioner were not tighten down completely during installation. When it rained, the water would seep through this gap and drain into the ceiling vents and drip into the bedroom. Not sure if this is your problem but my slides were in as well and this has been fixed and problem solved. Hope this helps.
2014 Legacy SR300, 340BH
Toad: 2011 GMC Acadia
" On the go to see something amazing"
- Psalm 107:23-24
lrob is offline   Reply With Quote
Old 05-21-2015, 09:44 PM   #5
TaterColo's Avatar
Thanks for the responses so far. With the slide cover I'm wondering how water could get in the slide?
Old 05-21-2015, 09:45 PM   #6
Rupkin2's Avatar
Try pulling out the bottom drawers ans have a look for any staining.
Maybe this will help to track the source.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 05-21-2015, 10:09 PM   #7
TaterColo's Avatar
Good idea. Thanks!
Old 05-21-2015, 10:16 PM   #8
TaterColo's Avatar
Nothing. Coming below.
Name:	ImageUploadedByForest River Forums1432264579.182890.jpg
Old 05-22-2015, 08:06 AM   #9
15berkxl's Avatar
Check the upper corners of the slides with slides in. My 2015 you could see daylight in those areas. Dealer had to redo the seals.
Wayne
15berkxl is offline   Reply With Quote
Old 05-22-2015, 10:00 AM   #10
Here's another theory.... That stain mark runs the whole length of the slide. Could it be condensation due to humidity in the air and temperature changes? The moist air condensing on the cooler metal/backing under the slide itself, picking up dirt, etc. and then falling/dripping along the edge because that sits lower than the rest of the slide? We store ours in a metal building and early Spring is horrible. Sometimes I'll walk into the building and the whole RV is covered in water droplets. Just like a cold glass on a hot/humid summer day.
LiteEmUp is offline   Reply With Quote
leak, water
