Old 03-30-2019, 01:35 AM   #1
Dijoeboss's Avatar
Cannot get roof a/cís to come on
First time Iíve tried using the a/c units since last summer, generator is running but neither a/c unit will come on. Itís something Iím missing, Iíve been up almost 20 hours and my mind is a mess. Any thoughts?? Flipped the breakers off and back on, verified the breaker on generator is on.
Dijoeboss is offline   Reply With Quote
Old 03-30-2019, 01:36 AM   #2
Dijoeboss's Avatar
ID:	200240Click image for larger version
Old 03-30-2019, 02:07 AM   #3
Dijoeboss's Avatar
Well I got them working, I cycled the coach battery disconnect switch in the entry way, the precision Plex screen reset and now they come on! Goodnight
Old 03-30-2019, 09:25 PM   #4
Dragonship Captain
Oscarvan's Avatar
Good night!
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 03-30-2019, 10:27 PM   #5
ernest917's Avatar
Check breaker on gen and make sure AC power is actually getting into coach....
ernest917 is offline   Reply With Quote
Old 03-30-2019, 10:28 PM   #6
ernest917's Avatar
Oops.... didnít see last pist
Old 03-30-2019, 10:29 PM   #7
ernest917's Avatar
Post.... lol...
Old 03-30-2019, 10:48 PM   #8
Got a question,,,we got our 2019 23mk in july and used it for the summer for weekend trips,,we had an issue that had me bring it back to the dealer a couple times,,,we would set the AC to 70 degrees and go in and take a nap,,camper was cool,,,we would wake up and it would be very warm in the camper ,,almost 80,,AC wouldnt turn on unless you would turn it off and baclk on again,,,the dealer checked it and said it was working fine...next trip,,same thing,,,any thoughts???
archer314 is offline   Reply With Quote
Old 03-31-2019, 01:36 PM   #9
Bluepill's Avatar
Digital thermostats have a microprocessor. So, like everything computer, they often need a reset/reboot from time to time. Also, sometimes after disconnecting the house batteries the thermostats need to be initialized. Your thermostat manual should tell you how to do it.
Old 03-31-2019, 07:57 PM   #10
I had the same problem kept taking it to the dealer and it work just fine but there was the one time the mechanic was going to show me that it was working and it failed to work so he got his meter and found no current after a circuit board in air conditioner he called the factory and they had some bad circuit boards. Both my air conditioner where doing this just Random was no pattern. I havenít had a problem since these circuit boards were changed out. My rig is a Sportcoach 2017 1/2 took almost a year before I got it fixed. When it was not working correctly we would play with it and get the units to work then we set thermostat to 65 and let run so they wouldnít cycle on and off.
Micman is offline   Reply With Quote
Old 04-01-2019, 08:36 AM   #11
Dijoeboss's Avatar
My set-up at Texas Motor Speedway
Boondockin..... no hook ups! Good times!
Old 04-01-2019, 08:38 AM   #12
Dijoeboss's Avatar
2 weekends ago on the Illinois River trout fishing!
Old 04-01-2019, 08:41 AM   #13
We have one of those multi zone multiple programmable Dometic thermostats.
We hate the complicated thing. It is difficult to work with. Hate it.
tomkatb is offline   Reply With Quote
roo, roof
