Thanks for all your replies !!
Original stat was discontinued so finished up with part# 3314082.000 - looks the same but does not have button for outside temp like the original (no big deal)
Plugged in the telephone type connector and display lit up, initialized and all set up. Tested zone 1 - HP, A/C and furnace and zone 2 A/C. All working perfect so $129 later all is good.
Now on another note - sat relaxing having a coffee outside feeling like a good job done when there was a sound of 'rushing air', I am thinking what the heck is that -air bag, air line and then I god the smell of propane. Dashed round to the tank and turned off the valve. I let the air clear for about 15 minutes then went to investigate - turns out there was a small pinhole 0.5mm or so in the regulator casting.
Off to camping world and picked up a new horizontal regulator $48; fitted and leak tested - all OK.
One of those days and thinking if the stat had not gone bad I would have probably been out at a Disney park - catastrophic does not even come close!!!
Turn the propane off when you leave the coach
2011 Berkshire 390RB (Front airbag upgrade & 275/80R tires)
