Old 07-22-2013, 08:38 PM   #1
JBoyer's Avatar
CCI PreTell 2 LP Detector - Last Rites
My CCI PreTell 2 detector started beeping today while I was working in the motorhome. I reset it, cleaned it, etc. I discovered today reading some original CCI (out of business now) material that the units had a 5 year - planned life. Once the unit starts beeping, it's on life support. I have seen the Safe-T-Alert, a direct replacement model that comes with the LP gas solenoid and is about $200. You can not use the Safe-T-Alert and original CCI solenoid as they use different voltages to operate. I also have read on several others forums that the gas valve is no longer required - and I have verified that. Seems to have dropped off the books around 2007ish... Many new builds don't include the solenoid either. I see many are taking the solenoid off and using a more standard LP or LP/CO combination detector. Has anyone here on the Berkshire forum done this? Is taking the solenoid off a difficult task? Need to solve this before leaving again in a couple weeks. As always, thanks all!
2015 Landmark Newport
2015 Silverado 3500hd dually tow vehicle
previous rig
2008 Berkshire pusher
2010 Mini Cooper Convertible toad
2015 Nissan Frontier toad
JBoyer is offline   Reply With Quote
Old 07-22-2013, 10:02 PM   #2
This is somewhat generic to your issue, but you may want to do a search for "mac the fire guy" on google. He was a vendor at a rally I attended recently and is an expert on all things safety related, including smoke, carbon monoxide and propane detecters.
His presentation on fire safety was a real eye opener; he even demoed how to spray yourself with fire retardant chemicals if caught in a burning coach (Yes, he actually sprayed himself down).
Folks if you don't already know it, you could have mere SECONDS to get out in case of a fire.
Boowho??
boowho is offline   Reply With Quote
Old 07-23-2013, 07:26 AM   #3
JBoyer's Avatar
Thanks - I will...
previous rig
