Old 05-19-2018, 11:08 PM   #1
HedgeRider's Avatar
Changing air filter
How do you access the engine’s intake air filter to change it on the Berkshire coach?
Dave
2016 Berk XL
Virginia
HedgeRider is offline   Reply With Quote
Old 05-20-2018, 08:02 AM   #2
Drivers side, rear of coach. Access is obtained from under coach.
2017 Berkshire XL 40 BH
2015 Jeep Cherokee Latitude
Locomo14 is online now   Reply With Quote
Old 05-20-2018, 05:14 PM   #3
HedgeRider's Avatar
thank you!
Dave
2016 Berk XL
Virginia
Old 05-22-2018, 05:57 PM   #4
It is a simple job with only two clamps. I used a little WD40 to slide the rubber back on the metal tube. I bought mine on Amazon for about a 100$.
zuckerburg is offline   Reply With Quote
Old 05-30-2018, 10:40 AM   #5
ernest917's Avatar
FYI: check ur air intake opening on the left rear and see if it has a screen covering the opening.... If not, you'll need to put one over the opening.... REASON - I had birds get in there and build a nest in the air filter which obviously reduced the needed air flow.... Had to remove the air filter and clean it out...
I bought some gutter mesh, painted it black and attached it with zip ties and no more bird nests.....
ernest917 is online now   Reply With Quote
