Old 09-20-2015, 01:13 PM   #1
gasman94's Avatar
changing LP regulator
Has anyone changed their LP regulator on a Berk? I tried last week, but was unable to turn (loosen) the regulator because when I did, the body of the reg. hits the LP tank. Any suggestions?
Rich
gasman94 is offline   Reply With Quote
Old 09-20-2015, 01:19 PM   #2
tmmar's Avatar
Rich,
Can you hold the regulator to keep it from turning while you undo the fitting? I haven't looked at it but that may be the case. I'm sure you have seen posts here of others who have changed their regulators without a problem.
Tom and Margaret
2014 Berkshire 390bh-60
Old 09-20-2015, 01:32 PM   #3
gasman94's Avatar
Ok, so I must be a moron.. Unless one of the threads on either the regulator or the tank valve fitting are reverse threads, the only way to get the regulator off is spinning the regulator. Am I missing something?
Rich
Old 09-20-2015, 03:07 PM   #4
silver's Avatar
One is a reverse thread.
silver is offline   Reply With Quote
Old 09-20-2015, 03:17 PM   #5
silver's Avatar
The attached has my extend a stay installed but shows the reverse thread coupling.
Old 09-20-2015, 03:59 PM   #6
gasman94's Avatar
Thanks Silver, I'm heading out to change it now.
Rich
Old 09-20-2015, 04:59 PM   #7
gasman94's Avatar
Done. Easy peasy! Only issue was a tube of gasoila thread sealer that I had with the regulator had turned to oil, so I used gas thread sealer. Just ordered another spare regulator and will get a pipe wrench for my coach tool box. Thanks.
Rich
