Old 11-02-2013, 11:40 PM   #1
Chassis Battery Charging on a Berk 360QS
How are the chassis batteries charged on a 2008 Berk 360QS? I received a 'system voltage low' warning today on my driver's console. When I checked the chassis batteries, they were at 12.3 volts. I'm charing them now with an external charger, but since I'm getting ready to hit the road on an extended trip, this is a bit worrisome. Suggestions/guidance greatly appreciated.
JohnKen is offline   Reply With Quote
Old 11-02-2013, 11:48 PM   #2
Chrisbrock's Avatar
Send a message via Skype™ to Chrisbrock
Shore power ?
Christopher Brock
2014 Sunseeker 3170ds
2012 Honda Odyssey
2003 Hummer H2
2003 IS300
Chrisbrock is offline   Reply With Quote
Old 11-03-2013, 12:11 AM   #3
Originally Posted by Chrisbrock View Post
Shore power ?
Well, that's what I hoped, but apparently not. Motorhome was in the shop for a week and was plugged in to shore power for at least the last day or two. Then 1 hour drive home. Problem occurred the following day.
John & Rosemary
2008 Berk 360QS
MBE 900-330 w/Allison 3000
Jeep Liberty Toad
Old 11-03-2013, 12:47 AM   #4
Chrisbrock's Avatar
Sounds like a problem in the charging system. I would start there.
Christopher Brock
2012 Honda Odyssey
2003 Hummer H2
2003 IS300
Old 11-03-2013, 07:59 AM   #5
AREA51's Avatar
JohnKen,
My 2008 360QS charges the house batterys when the engine is running and when when the genset is running. Also when plugged into shore power. Sometimes when I light off the coach I get the "system low voltage" with a voltage reading warning, but it shortly goes away. If you check the three 12V power outlets, you will see that one of them is tied to the house batteries and is always powered up as long as you have the 12V switch on by the front door. I usually carry on of those little LCD volt meters that plugs into the 12V outlet, with that you can see which is powered up with the ignition off. It also gives the voltage so you can see when everything kicks in and the voltage increases.
GOOD LUCK
AREA51
AREA51 is offline   Reply With Quote
Old 11-03-2013, 09:07 AM   #6
I get that same warning all the time on my '11.
Yet the engine always cranks in a "lively" manner; never sluggish.
I may get a nasty surprise someday, but for now I've dismissed it as a false alarm.
Boowho??
boowho is offline   Reply With Quote
Old 11-03-2013, 10:52 AM   #7
Thanks for the tip, Area51. Hadn't thought about the accessory plug for easy access for voltage check . Now I've just got to find my digital meter. Still trying to get organized for full-timing. BooWho??: engine cranked fine on my rig as well, but after a short period of idle, an 'auto idle' function kicked up the RPMs. I was outside the coach and thought the DW had her foot on the accelerator! Charged the batteries with an external charger last night, so perhaps, that's all that's needed. Guess time will tell...
John & Rosemary
2008 Berk 360QS
Jeep Liberty Toad
Old 11-03-2013, 03:19 PM   #8
Learning
Have the same coach, got the same message. It would go away but return on start up. Replaced the start batteries and it went away. Apparently it senses bad batteries.
2008 Berkshire 36SQ, 2012 Honda CRV
Edward972 is offline   Reply With Quote
Old 11-03-2013, 04:11 PM   #9
I would think if the voltage dropped to 12 v and it hasn't sat for awhile the batteries are bad. I would have someone check them or it cause the alternator to fail also.
Old 11-03-2013, 04:45 PM   #10
Batteries are nearly new. Interstate 'no maintenance' installed by previous owner in March this year. Charged them overnight last night and they seem to be holding a charge OK. I'll definitely be keeping an eye on them and will load test them at my earliest opportunity. Also wondering if low voltage might have caused the Water In Fuel warning that has periodically popped up. Each time I checked, I could not detect any moisture in the fuel I drained. Just another of life's great mysteries to ponder...
John & Rosemary
2008 Berk 360QS
Jeep Liberty Toad
battery, charging
