Old 12-21-2015, 08:42 AM   #21
accumack's Avatar
Is that something plugged into the outlet? If so that is most likely the block heater.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 12-21-2015, 08:52 AM   #22
tmmar's Avatar
That black cord hanging down in front of the outlet has a plastic cover over the male prongs. Remove the cover and plug it into the outlet on the wall when you want to use the block heater. You need to be plugged into ac for the outlet to work.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 12-21-2015, 09:12 AM   #23
jegstrup's Avatar
Oh ok, I thought this was going to be something I mugged into shore power.
I guess my block heater has been plugged in this whole time.
I should unplug it since I'm paying for electricity where I'm parked
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
jegstrup is offline   Reply With Quote
Old 12-21-2015, 09:54 AM   #24
accumack's Avatar
Yes just plug it in the night before you are going to start the coach if it is cold out.
Ham KG5LTL.
Old 12-21-2015, 10:04 AM   #25
Kenny kustom's Avatar
You only need a couple hours before you are set to leave.
Any more is a waste.
Up here ( where you actually NEED a block heater) I have a timer set for three hours. I start plugging in at -15c.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-21-2015, 08:00 PM   #26
oldkeywest91's Avatar
We found that the crossconnect switch in the coach battery compartment was losing 1.0/1.5 amps to ground,with all battery switches turned off.Found that the crossconnect switch is wired around the on/off battery switch and is hot all the time.Bought another kill switch and wired crossconnect feed wire through it with new wire to battery and now no dead batteries
oldkeywest91 is offline   Reply With Quote
Old 12-22-2015, 08:33 AM   #27
CAT-RN's Avatar
There is a breaker that will shut power off to that outlet also. My breaker says block heater.
Russell
CAT-RN is offline   Reply With Quote
battery
