Old 08-14-2016, 10:00 AM   #11
rattleNsmoke's Avatar
I would suspect a 'weak' battery or charging system. But then again I've been known to be way off base too.
1988 Harley Softail Custom "The Fireman"
rattleNsmoke is offline   Reply With Quote
Old 08-14-2016, 11:10 AM   #12
Kenny kustom's Avatar
Depending on length of time the message is displayed...
All vehicles will display the check engine light when starting.
It is a requirement of the emissions system to do a " bulb check" , to ensure the light works.
Not saying there may or may not be an issue.. just my 2 Canadian pennies.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Bring Back The Search!
Old 08-14-2016, 12:55 PM   #13
fredhardy's Avatar
Tom - the engine check light resolved itself. I would run it down the road and see what happens.
Regards,
Fred
Fred Hardy
Phoenix, AZ
2014 Berkshire 390BH-60
2007 Explorer Sport Trac
fredhardy is offline   Reply With Quote
Old 08-15-2016, 01:04 PM   #14
tmmar's Avatar
I added about 3/4 gallon of antifreeze to the over flow tank (tank was down about 1/2 way). Also, I don't have a solid check engine light. The check engine light goes out after the bulb check finishes but I get a message on the screen that says '! Check Engine' but that goes off quickly also.
Tom and Margaret
2014 Berkshire 390bh-60
Old 08-24-2016, 02:41 PM   #15
My Low Battery lite would come and go, then on all the time, bad alternator.
F14man is offline   Reply With Quote
Old 09-02-2016, 05:22 PM   #16
Had the same problem as F14 . Check your dash monitor for the voltage out put. I needed a new alternator also. If your voltage drops below a certain number your engine will shut down. Jim
jrlebaron is offline   Reply With Quote
Old 09-02-2016, 06:39 PM   #17
15berkxl's Avatar
The confusing part of the monitor system is that there are three what I will call check engine lights. The first time I received a light I thought it was an engine concern but learned it was a light that looks like an engine but does not say anything but is for the monitor system it clears with 5 key activations. The other two one says check and the other says stop.
Wayne
Wayne
15berkxl is offline   Reply With Quote
