Old 04-29-2014, 12:38 PM   #1
Check Engine/water in fuel
We're on a shakedown cruise and having some issues:
Left home with a little more than a 1/4 tank. Filled up before leaving town. Drove 1.5 hrs, camped for the night, then drove another hour to the first stop.
When we left that first stop, the "Water in fuel" notification came up on the information center (but no win he warning lights). I pulled over, left the engine idling, and looked through the manuals. It wasn't too clear what action to take.
In the process, I hit the Information Center joystick, and the Water in fuel notification went away.
We drove on down the road, but 10-20 miles later, I got the engine warning light, plus "engine warning" in the display. I immediately looked for a place to pull over, and as I did, the engine warning light went out, and everything g appeared normal.
Now I'm parked, and when I turn on the key, it shows the engine arming light, "engine warning" in the display, followed by "water in fuel". After 3 seconds, the engine warning light goes off off, but the water in fuel notice remains until I hit the joystick.
All this sounds like it needs service. However, there is one more thing: the generator won't start. The charger shows 12.4v on the batteries, and the in error seems to be working correctly. It when I hold the top of the Generator Start switch, it makes a fast ticking noise, but nothing else.
I'm just wondering if it's an overall electrical problem, and the two are related. Or maybe not.
Not sure what I'm going to do at to this point...
chesterhull is offline   Reply With Quote
Old 04-29-2014, 12:46 PM   #2
tmmar's Avatar
Would help to know what year, model and the mileage you have on the coach. As for the ticking noise, the generator needs the glow plug to warm up before the generator starts. This could be a normal situation. I would hold the start switch a little longer to see if it starts. Also, your fuel water separator my need changing. Do you know if/when this service may have been performed?
Tom and Margaret
2014 Berkshire 390bh-60
Old 04-29-2014, 12:47 PM   #3
Ha! Sorry! I'm in a 2008 390bh...ISB 6.7 Cummins. 10,800 miles. It has sat in a storage lot for the past year. I just bought it a few weeks ago.
Old 04-29-2014, 12:54 PM   #4
avolnek's Avatar
Drain off your fuel filter housing to remove any water that may be in the filter housing.
after draining the fuel/water close the valve and to prime the fuel bowl again you need to turn the ignition on for 5-10 seconds. Shut off. and repeat 3 or four times. This will have the lift pump send fuel to replace the fuel you drained off out of the bowl.
Most likely you picked up a minimal amount of moisture in your fuel and it needs to be bled out!
If you need a helpful hand finding the fuel filter housing just shout and I can get you a picture of what it looks like.
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 04-29-2014, 01:17 PM   #5
tmmar's Avatar
As avolnek indicated, you may have picked up some water. If you look on the passenger side of the engine, you will see a filter with a clear, yellow bowl and a black knob on the bottom. If you turn the knob it will open and you can drain some of the fuel/water out. It won't drain completely because it is gravity fed and fuel will continue to flow into the filter. Don't ask me how I know this -ok, the first time I change the fuel water separator, fuel kept pouring out and I got a soaking in diesel fuel. If that doesn't fix the problem, you may need to change the fuel/water separator completely.
Tom and Margaret
Old 04-29-2014, 01:21 PM   #6
avolnek's Avatar
I would also recommend replacing the filter at the same time if at all possible! Otherwise this is a quick bandaid... would recommend the filter sooner than later though... water into the cummins injectors can spell bad news!
Old 04-29-2014, 02:03 PM   #7
Ok, thanks. I'm draining it now. Does it ever stop? I drained for about 10 minutes, and it was still going strong. I closed it, turn on the key for a few seconds (until the noise stopped) and then opened it again. It's been draining for almost another 10 minutes now. (It still showed "water in fuel"). Click image for larger version
Name:	ImageUploadedByForest River Forums1398798198.637431.jpg
Old 04-29-2014, 02:09 PM   #8
avolnek's Avatar
You missed what tmmar said... he said it continued to pour out as long as it is open... Must be siphoning from the tank...
You may need to pull the housing off completely and drain it by holding it upside down. Or just completely replace it. I am not terribly familiar with the motor home style of cummins. VERY familiar with the light truck applications though...
Old 04-29-2014, 02:12 PM   #9
tmmar's Avatar
As I said in my earlier post, it will continue to flow as long as the valve is opened because it is gravity fed as long as the fuel is higher than the level of the filter. If you still get the water in fuel light, it is probably a bad load of diesel. Not sure if it will be resolved by just changing the filter. Don't know what the next step would be. Did you try starting the engine to see if it resets?
Tom and Margaret
Old 04-29-2014, 02:17 PM   #10
You've drained more then enough fuel. That receptacle, is where the water collects when it gets separated. Once that is drained off, your good to go again.
It may take a couple of on and off cycles and a little travel time to clear the code, kinda like the loose gas cap thing on some cars. You can snug the cap, but until you've driven a bit, and turned the ignition on and off a few times, the check engine light will stay on.
katkt is offline   Reply With Quote
water
