Old 09-12-2016, 04:48 PM   #1
Check Valve
Anyone know the part number for the city water intake check valve? We have 2011 Berkshire 390RB, and have tried 2 different valves available locally, but each one still allows water to leak when not connected to city water. Thanks.
RLHAMILTON is offline   Reply With Quote
Old 09-12-2016, 04:54 PM   #2
Not an answer to your question but another possible solution... get one of *THESE* and screw into your city water connection port when using the pump. It will stop the water from leaking out.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-12-2016, 06:24 PM   #3
ernest917's Avatar
Since I recently dealt with this issue let me tell you what I did - I totally replaced the city water fill unit.... Cost abt $30 and I replace it with a solid brass unit instead of the plastic unit I replaced.... Took a total of abt 10 minutes....
Simply remove the screwed on cover in the water bay and then unscrew the water line from the back of the existing unit.... Unscrew the existing unit and remove it... Put the new unit in the hole, reattach the water line, screw the new unit down and the replace the cover your removed earlier and it a done deal....
ernest917 is offline   Reply With Quote
