Old 05-24-2016, 04:57 PM   #1
tnbendr's Avatar
Checking batteries
This might sound like a silly question, but should I disconnect shore power when checking battery levels?
Ben & Michelle
2015 Berkshire 38A
2005 Jeep Wrangler toad
tnbendr is offline   Reply With Quote
Old 05-24-2016, 05:12 PM   #2
Flybob's Avatar
If you are talking about checking water levels visually, then it is not a bad idea to at least insure that power to the battery is off as opening the fill ports can release hydrogen gas and an accidental short in an enclosed area could cause a problem.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-24-2016, 05:39 PM   #3
If I want to check the water level in my bank of batteries then the batteries have to come out. No other way to see the water level
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 05-24-2016, 06:07 PM   #4
Checking batteries
The battery boxes on Berkshires, a class A motorhome are extremely well ventilated. It is my experience that to check water levels does not require anything more than opening the cabinet door and looking at the battery's water level. Make sure to fill with distilled water.
Paul
2015 XL 40QL-60
2015 Jeep Wrangler Unltd. Sahara
Paulie Boy is offline   Reply With Quote
Old 05-25-2016, 07:14 AM   #5
tmmar's Avatar
Not sure if tnbendr means the water level or the voltage level of the batteries.
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-25-2016, 12:14 PM   #6
Fulltime in our Berkshire
KennyGolub's Avatar
Paul
2015 XL 40QL-60
X2
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 05-25-2016, 05:18 PM   #7
tnbendr's Avatar
Yes, I did mean water levels and I did disconnect shore power because I had to loosen a couple of connections to move them away from caps.
Thanks all!
Ben & Michelle
2015 Berkshire 38A
Old 05-25-2016, 05:28 PM   #8
tmmar's Avatar
Ben,
Great- just as long as you got the right answer to your question.
Tom and Margaret
Old 05-25-2016, 05:37 PM   #9
tnbendr's Avatar
Ben,
Ben & Michelle
2015 Berkshire 38A
battery
