Old 10-29-2012, 07:40 PM   #1
JBoyer's Avatar
Clips used for water compartment - name??
Hello all. Today while winterizing our 08 Berkshire, I noticed an issue on the water compartment door. One of the clips is completely missing and the other appears broken, or at least not attached right, as it moves from side to side.
My question is what are these clips called? I need to get replacements but I've looked all day and not found a similar item.
Thanks everyone.
JBoyer is offline   Reply With Quote
Old 10-29-2012, 07:44 PM   #2
Berkshire 390QS
NO3putt's Avatar
can you post a picture? I think I know what your talking about, the clips that hold the door closed?
Skip
Old 10-29-2012, 07:50 PM   #3
JBoyer's Avatar
I will try to get a picture tomorrow. There are a clip with a safety pin - of sorts to hold the door closed. Not real substantial - but when actually "on the door", I suspect they work well enough...
Old 10-29-2012, 08:03 PM   #4
Berkshire 390QS
NO3putt's Avatar
replacement idea
i gave up on the little clips and replaced them with pop up camper clip.
Used two rivits to attach to door.
Skip
Old 10-29-2012, 08:10 PM   #5
accumack's Avatar
i think they are called hairpin clips. Lowes has them in the tray boxes in the hardware aisle
accumack is offline   Reply With Quote
Old 10-29-2012, 08:31 PM   #6
JBoyer's Avatar
There is a hairpin clip that "locks" the mechanism - I apologize for not being more clear. I'm missing the entire thing - spring clip, lock and pin - there is nothing down there on one side and only a half rotten clasp on the other...
Old 10-31-2012, 10:58 AM   #7
AREA51's Avatar
Draw Latch
These are called a draw latch and below are two sites that may carry what you need. When I picked up my Berkshire one was broken on the compartment tha contains the water pump, the dealer ordered one and replaced it for me. I'm not sure who he ordered from but I'll bet Forest River will send you one if you ask.
http://www.protex.com/product/index/category/Light+Duty/subcategory/Rigid+Fasteners
http://www.mcmaster.com/#standard-draw-latches/=jylxfj
Good luck,
AREA51
AREA51 is offline   Reply With Quote
Old 10-31-2012, 02:08 PM   #8
tmmar's Avatar
Lowes has them. One of mine came off and I found a replacement at Lowes. Drilled out the rivets holding the piece on the door and used a screw to hold in place. Also drilled holes for screws to hold the latch piece. I believe that they may also be called suitcase latches.
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-31-2012, 02:48 PM   #9
AREA51's Avatar
Draw Latch
This looks like the McMaster Carr Part Number
Good luck
ARE51
Work-Load Rated Draw Latches
<DIV> (A) Padlockable with Button Strike
Here's a work-load rated solution for securing enclosures, containers, and cases. Mounting screws not included.
Padlockable Latches—Maximum padlock shackle diameter is 5/16" for Style A, 3/8" for Style B, and 1/4" for Style F.
Note: Work load limit is the maximum amount of force the latch can withstand without affecting its operation or appearance.
For technical drawings and 3-D models, click on a part number.
<DIV class="ItmTblCntnr PrsnttnTbl"><DIV class=ItmTblGrp>Overall Size
With Square
Strike
With Button
Strike
MaterialLatch
DistanceLg.Wd.Proj.Work Load
Limit, lbs.Screw
Size Each EachPadlockable
AZinc-Plated Steel1 11/16"3 3/8"15/16"15/16"285#81844A53$7.821844A43$7.82
<DIV style="MARGIN: 0px 123px 0px 131px; WIDTH: 398px" class=InLnOrdWebPartLayout_CntntDiv><DIV style="WIDTH: 386px" id=InLnOrdWebPart_RacingStripe1844A53 class="InLnOrdWebPartLayout_Overlay InLnOrdWebPart_RacingStripe">
CAD|Catalog Page|BookmarkBookmarked
Old 10-31-2012, 07:31 PM   #10
JBoyer's Avatar
DRAW LATCH! Perfect - that's exactly it. Thanks so much everyone for your assistance.
