03-20-2019, 09:46 PM
Closed Step
Well, we r sitting here in our CG site and I just opened the door to discover that my step has closed.....
I now can’t get it to open..... didn’t do anything to cause it to close so I’m at a loss..... tried turning switch by door off/on; tried starting Diesel engine- no luck...
Guess I’ll check fuses in the morning....
03-20-2019, 09:50 PM
Dragonship Captain
On mine fuse under drivers side window. Left one of the three. Also, there is logic that retracts it when the ignition is on. (Don't have to start). So make sure key is OFF when you're testing for 12V.
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
03-20-2019, 09:56 PM
I tried turning key off/on and then opening door - nothing.....
03-20-2019, 10:30 PM
Dragonship Captain
Multi meter time....
03-20-2019, 10:34 PM
Ck fuses first...... steps have been open for over 3 months - open an hour or so earlier.....
03-21-2019, 10:18 AM
Don't have a Berkshire but typically there is a door open/closed sensor typically a switch (typically magnetic) and it might pay to check it if fuses are ok.
03-21-2019, 05:51 PM
Step just decided to open on its own..., Crazy....
03-21-2019, 08:29 PM
Dragonship Captain
Bad sensor on the extension mechanism. Take it apart and see how it works and if there's anything obvious there. Or just wait until it really breaks.
03-22-2019, 11:49 AM
2014 360 QL
there is also a control module but i have never had any problem with it,, mine done that once ( had it out for 6 mo. and didnt want to come back in ) i loosen the linkage just a little bit and been working fine ever since
2014 360 ql
03-22-2019, 05:56 PM
Dragonship Captain
Ahhh, is the stop a friction/resistance cutout?
03-22-2019, 08:07 PM
If the steps are Kwikee/Lippert they are current limit controlled for extension and retraction. You have a Berkshire, what are yours?
03-22-2019, 08:19 PM
Dragonship Captain
That's them.
