Old 03-20-2019, 09:46 PM   #1
ernest917's Avatar
Closed Step
Well, we r sitting here in our CG site and I just opened the door to discover that my step has closed.....
I now canít get it to open..... didnít do anything to cause it to close so Iím at a loss..... tried turning switch by door off/on; tried starting Diesel engine- no luck...
Guess Iíll check fuses in the morning....
ernest917 is offline   Reply With Quote
Old 03-20-2019, 09:50 PM   #2
Dragonship Captain
Oscarvan's Avatar
On mine fuse under drivers side window. Left one of the three. Also, there is logic that retracts it when the ignition is on. (Don't have to start). So make sure key is OFF when you're testing for 12V.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 03-20-2019, 09:56 PM   #3
ernest917's Avatar
I tried turning key off/on and then opening door - nothing.....
Old 03-20-2019, 10:30 PM   #4
Dragonship Captain
Oscarvan's Avatar
Multi meter time....
Old 03-20-2019, 10:34 PM   #5
ernest917's Avatar
Ck fuses first...... steps have been open for over 3 months - open an hour or so earlier.....
Old 03-21-2019, 10:18 AM   #6
bubbles's Avatar
Don't have a Berkshire but typically there is a door open/closed sensor typically a switch (typically magnetic) and it might pay to check it if fuses are ok.
Old 03-21-2019, 05:51 PM   #7
ernest917's Avatar
Step just decided to open on its own..., Crazy....
Old 03-21-2019, 08:29 PM   #8
Dragonship Captain
Oscarvan's Avatar
Bad sensor on the extension mechanism. Take it apart and see how it works and if there's anything obvious there. Or just wait until it really breaks.
Old 03-22-2019, 11:49 AM   #9
2014 360 QL
po 185's Avatar
there is also a control module but i have never had any problem with it,, mine done that once ( had it out for 6 mo. and didnt want to come back in ) i loosen the linkage just a little bit and been working fine ever since
2014 360 ql
po 185 is offline   Reply With Quote
Old 03-22-2019, 05:56 PM   #10
Dragonship Captain
Oscarvan's Avatar
Ahhh, is the stop a friction/resistance cutout?
