Old 06-13-2016, 04:38 PM   #11
CAT-RN's Avatar
I like free!! I'll take four!!
Russell
CAT-RN is offline   Reply With Quote
Old 06-13-2016, 04:47 PM   #12
Berkshire 390QS
NO3putt's Avatar
Dan, need a few here also. LOL
Skip
Old 06-13-2016, 04:51 PM   #13
dan-nickie's Avatar
I forgot to say it was a very very small bag. LOL
Dan
2014 Berkshire 390RB-60
dan-nickie is online now   Reply With Quote
Old 06-13-2016, 05:17 PM   #14
tmmar's Avatar
Oh sure!! Start back pedaling now! That will teach you not to share so much info next time!!
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 06-13-2016, 11:46 PM   #15
I learned the hard way that these latches do a terrible day od holding when the rv is in motion.
One of the doors slammed open and Árashed into the handle of the second door. The impact caused the door frame to break and the mirror to become loose. After using epoxy to fix the frame I turned my focus to a way of locking the doors in place.
I cut two pieces of dowel that would be used to fit between each door and the frame.
In order to make removal of the dowel dowel easy ... I glued two pieces of 1/4 inch dowel to the top of each.
lefaivre is offline   Reply With Quote
Old 06-17-2016, 07:31 AM   #16
I-RV's Avatar
X2 lefaivre. One of my doors slammed open on the way home from picking up the new MH. The door frame split apart at one corner, I tried other latches, including the roller style. The doors are just too heavy. The final solution is wooden dowels in the track. I just made a tab handle by folding over a piece of duck tape in the center.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 06-18-2016, 09:54 AM   #17
Gottawonder's Avatar
I had some pvc pipe in the garage and cut a piece to fit
2014 Jeep Wrangler Unlimited
Roadmaster Falcon A/T tow bar
Gottawonder is offline   Reply With Quote
door, replacement
