Originally Posted by SlowrideHD
Just put smaller amounts in the washer and drier and you won't have near so much out of balance shaking.
These washing machines are already small enough! The dryer isn’t an issue at all when it’s on and running. Just the washer and only when it’s spin cycling.
Again, I put the ‘spin’ amount on LOW but that doesn’t spin out as much water and therefore the dryer has to run 3 tones as long (literally 3x). But it’s not the end of the world. However, even with a low spin cycle selected, it still goes crazy a couple times per cycle. And ultimately I’m assuming all this shaking can wallow-out screw holes or loosen up mounts on the back wall or even split/crack it. All this shaking over time can’t be good.
I’m definitely interested in improving the shaking. I will try to get access to bottom where it’s mounted and check that to see how stable it’s mounted. I appreciate all the responses and pics.
