Is anybody else having issues with the seat belt shoulder harness pulling the screws out of the window valance? Does anybody have a resolution to this. Really bad design!
Funny when I was buying our coach I thought the kitchen back splash was real tile. Wasn't till a couple weeks after I got her home that I noticed it was just a fancy high polished particle board. lol
I think I would cut out that forward section of valance support hole where the seat belt passes through (maybe a little larger). If it's cardboard apply some epoxy glue over exposed edge to keep cardboard from coming apart. If it's due to the valance (fabric portion) itself then good luck.
The seat belt doesn't pass through a hole so, I have no clue what you are suggesting.
You're right sorry. The seatbelt support coming off the wall. I believe it swivels with seatbelt usage and may cause the issue. If not, you'll figure something out.
Mine I think are thin luan plywood. I would use small tee-nuts.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
