Old 11-27-2015, 09:57 AM   #21
mikeborny's Avatar
Name:	ImageUploadedByForest River Forums1448639761.805047.jpg
Name:	ImageUploadedByForest River Forums1448639802.688994.jpg
Hooked up new batteries and getting this fault message?
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 11-27-2015, 10:18 AM   #22
tmmar's Avatar
Mike,
That magnum piece that you show in your picture gets connected to the negative terminal with the cable. You should hook them both up under the same nut to the rear negative terminal closest to the back wall of the compartment. I think that will solve you issue.
Keep us informed.
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-27-2015, 10:20 AM   #23
mikeborny's Avatar
Hooked up new batteries and tha magnum sensor and i got the fault messages in last post.
Old 11-27-2015, 10:21 AM   #24
tmmar's Avatar
Did you look at the magnum in the compartment itself? Possibly a breaker on the magnum needs to be reset.
Tom and Margaret
Old 11-27-2015, 10:22 AM   #25
mikeborny's Avatar
Can't find a breaker or fuse on inverter.
Old 11-27-2015, 10:30 AM   #26
Campin Cajun's Avatar
Mike the breaker is behind the inverter. You will not be able to see it. Reach in right on top the inverter and to the right a little on the back side. You will feel the breaker/ switch. Turn it off then on again.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-27-2015, 10:31 AM   #27
tmmar's Avatar
Also, there should be a 2 push buttons on the inverter that could need resetting.
Tom and Margaret
Old 11-27-2015, 10:39 AM   #28
mikeborny's Avatar
Name:   ImageUploadedByForest River Forums1448642298.385695.jpg
I can not feel anything behind inverter. Do you have this one?
Old 11-27-2015, 10:41 AM   #29
No sorry Mike I have a different one. Mine doesn't look anything like yours.
Old 11-27-2015, 10:42 AM   #30
mikeborny's Avatar
Thanks, at least i believe it is an inverter problem.
charging, battery
