Old 11-27-2015, 01:29 PM   #41
2011 Berkshire 390BH
Superchief's Avatar
Name:	ImageUploadedByForest River Forums1448652477.215569.jpg
ID:	95153Click image for larger version
Name:	ImageUploadedByForest River Forums1448652491.195634.jpg
ID:	95154Click image for larger version
Name:	ImageUploadedByForest River Forums1448652502.988395.jpg
ID:	95155Click image for larger version
Name:	ImageUploadedByForest River Forums1448652526.791668.jpg
ID:	95156Click image for larger version
Name:	ImageUploadedByForest River Forums1448652539.135130.jpg
ID:	95157Click image for larger version
Name:	ImageUploadedByForest River Forums1448652550.819509.jpg
Theses might help!
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 11-27-2015, 01:36 PM   #42
mikeborny's Avatar
Thanks for the screen shots superchief, I came back from a walk and plugged in the shore power and hit the on button and it seems to be working now. Showing an absorb charge now and full batteries. In all of this I noticed the test button for the remote generator start. Is that supposed to go on automatically when batteries get to low?
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 11-27-2015, 02:08 PM   #43
7 Year Class A RV'er
Assuming you have AGS in your Magnum system, you program the gen to start at a preset temp inside the coach and/or at a preset voltage on the batteries.
2015 Legacy SR340 360RB
Old 11-27-2015, 02:22 PM   #44
Superchief's Avatar
Mike, When in absorb charge, my batteries also show full charge on the "light post", but they are not. They are in process. As for the green light on the controller, it should be on for inverter and on for charger. If you turn the charger off in my controller, it says, charger standby. Did you happen to program the controller for the type of new batteries that you just installed? If you need more screen shot of the manual, let me know. Craig
Craig
Old 11-27-2015, 02:35 PM   #45
mikeborny's Avatar
I will have to figure out how I set that up.
Old 11-27-2015, 02:40 PM   #46
mikeborny's Avatar
Craig, thanks again, and I have the manual at home and will go through it tomorrow and set it up. I did not you needed to do that. I have only had this RV since June and it is a little more complicated than my gasser.
Old 11-27-2015, 02:44 PM   #47
Superchief's Avatar
Name:	ImageUploadedByForest River Forums1448657067.469833.jpg
Craig
Old 11-27-2015, 03:16 PM   #48
mikeborny's Avatar
Name:	ImageUploadedByForest River Forums1448658662.547035.jpg
Name:	ImageUploadedByForest River Forums1448658691.994474.jpg
Ok, went in to check on charging and system monitor says new batteries at 2/3 and I am hooked up to shore power. I turned off charger and charger standby shows 9.8 volts. What should that read.
Old 11-27-2015, 03:25 PM   #49
If your converter is off and your batteries are at 2/3 it should read something like 12.3 volts.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 11-27-2015, 08:52 PM   #50
Superchief's Avatar
Mike, Do you now have power so you can retract jacks or get slides in? Craig
Craig
charging, battery
