Old 11-27-2015, 08:58 PM   #51
mikeborny's Avatar
Craig, yes I put 4 new coach batteries in and have power. But I still have a feeling not everything is working properly. When you turn off light switch in bedroom, the lights don't go off all the way? And control panel still shows batteries at 2/3 charge while hooked up to shore power. Will be calling Magnum next week to talk with service department to walk me through problems.
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 11-28-2015, 08:53 AM   #52
Since I do not have a combination inverter/converter some of the potential issues are different for me. However, if you are plugged into shore power the inverter should be bypassed and the AC flowing to the outlets from the shore power connection. Is the inverter light normally green in these cases? When I see the "stuck relay" fault, could that be the internal transfer relay in the unit. If it is stuck and is continuing to power the 110V outlets using the inverter, you could be drawing significant DC current from the batteries even though you are on shore power.
Those vaults would bother me.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 11-28-2015, 08:58 AM   #53
If the converter is working and everything is wired correctly, your panel should always show full charge with a shore power connection. This means that the converter section is putting out more than a fully charged battery bank (around 13.3 volts or so.) If you really are at 2/3, the converter should be working and bumping the voltage up to 13.3 or so when connected.)
Lights not going off all the way also indicates some errant wiring, depending on the actual circuit wiring (grounds, etc)
2015 335DS
Old 11-28-2015, 01:05 PM   #54
Campin Cajun's Avatar
It's a phenomena of some LED lights. When I turn my lights off in the bedroom they don't go off all the way, there is still some light coming from them. I notice it at night when we are going to sleep. When we wake up the lights are completely off.
This is not a wiring problem.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-28-2015, 01:15 PM   #55
tmmar's Avatar
I have experienced the same issue with my lights. We turn off the bedroom lights and they continue to glow slightly.
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-28-2015, 01:20 PM   #56
I think it's because the LED bulbs use less electricity so it take awhile to use up the extra electricity left in the wire when you turn off the switch. There is a lot of wire so it takes some time. Right?
Old 11-28-2015, 01:38 PM   #57
tmmar's Avatar
Sounds right to me!
Tom and Margaret
Old 11-28-2015, 01:44 PM   #58
Fulltime in our Berkshire
KennyGolub's Avatar
K
ROFLMAO
Now That is funny, I don't care who you are
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 11-28-2015, 02:23 PM   #59
That's funny Phil....lol
Old 11-28-2015, 02:27 PM   #60
Umbrella drinks early today Phil?
Paul
Paulie Boy is offline   Reply With Quote
charging, battery
