Old 11-28-2015, 02:33 PM   #61
Originally Posted by Paulie Boy View Post
Umbrella drinks early today Phil?
Paul
Yup!
Old 11-28-2015, 02:34 PM   #62
Darn Buckeyes ruined a clean sweep. Oh well go MSU!
Old 11-28-2015, 04:29 PM   #63
Is there a battery isolation/shut off switch that may be between the coach and charging circuit that is off or wired wrong? Has this always been a problem? Do you have a VOM (volt ohm meter) to check the voltage at the batteries? If you are getting voltage from the charging circuit to the batteries (should me higher than battery voltage) but then after unplugging or shutting engine down and the batteries are lower than rated voltage then they are not taking or holding charge and you need to replace them!
jz5w63 is offline   Reply With Quote
Old 11-30-2015, 12:04 PM   #64
mikeborny's Avatar
After talking with Magnum tech today, and trying to reset the inverter, it looks like an inverter issue! One item discovered is that the battery shutoff for coach does not cut the power to the magnum comm center. I had to disconnect the inverter lead from the batteries to cut powere to the comm center in coach. That does not make sense to me. Nearest service shop 2 hours away! At least it is under warranty.
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 11-30-2015, 12:09 PM   #65
I agree. On my coach the shutoff switch cuts off virtually everything from the batteries...after all...it is a shutoff switch!!!! This includes BOTH of my inverters!
2015 335DS
ScottBrownstein is online now   Reply With Quote
charging, battery
