Old 11-22-2013, 05:10 PM   #1
JTN8's Avatar
Coach won't start
So my coach won't start and the chassis batteries are only reading 3.6 volts. I tried the aux start and I get nothing. My house batteries are full and the coach is plugged into 50amps! Does anyone have any ideas on what to do and can I jump start the coach off the house batteries???
Jason
Old 11-22-2013, 05:27 PM   #2
10x
Jason
You should be able to jump them with cables if the house batteries are 12 volt.
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 11-22-2013, 05:30 PM   #3
Berkshire 390QS
NO3putt's Avatar
Can you start your genny? If so I think they will charge up your coach batteries after the house batteries are fully charged. How long has your unit been sitting? Any lights, warnings showing up on dash?
Old 11-22-2013, 06:10 PM   #4
JTN8's Avatar
My coach is plugged in. Won't that charge the batteries?
No I get no lights at all on the dash or anything. They are completely dead. Does the generator charge the chassis batteries?? If so why wouldn't shore power?
Old 11-22-2013, 06:15 PM   #5
tmmar's Avatar
Could the battery shut off switch gotten turned to the off position somehow? Also, check to see if there are any fuses/breakers in the battery compartment or on the inverter that could have tripped.
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-22-2013, 06:20 PM   #6
10x
Are the battery terminals corroded?
2014 XLR 27 HFS
Old 11-22-2013, 06:27 PM   #7
kingwood390bh's Avatar
A battery charger or a 12 volt jump start should give you an indication of where to start. As soon as you connect a charger to your batteries you should get dash lights even if the unit still wont start. Also, the toggle switch on the dash, (AUX) should allow for battery sharing to start the unit.
kingwood390bh is offline   Reply With Quote
Old 11-22-2013, 06:31 PM   #8
Batts-toy's Avatar
Jason
If you have another vehicle available and jumper cables I think you should take that approach. With only 3.6 volts that battery is totally dead (or badly corroded cables at the posts 10x may be spot on) and will have to be cycled up with an alternator or a good charger that has the ability to cycle up dead batteries. You will have to let the jumper cables have time to charge your battery for a while before attempting to start your coach.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 11-22-2013, 06:48 PM   #9
JTN8's Avatar
Aux start won't work!! Not sure why since house batteries are full and coach is plugged in. Ran jumper cables from my house batteries to chassis batteries and all lights came on but I fried my cables!! Don't think they were strong enough for the voltage!!! Going to get better cables and try tomorrow. Still don't understand why my aux start won't work though!!! Is there anything special I need to do to make it work???
Old 11-22-2013, 07:01 PM   #10
10x
Your batteries for your engine are a separate circuit, they are not connected to the house batteries. Sounds like you need new batteries for you engine. How old are they?
2014 XLR 27 HFS
