Old 06-03-2016, 11:00 PM   #1
Condensation in headlights
I have a 2012 390BH60 that has condensation in the passenger side headlight. Can anything be done to remove this or do I need to replace the entire unit. If so do I need to purchase it from Forest River or is it a repurchased part from a common auto manufacture?
lefaivre is offline   Reply With Quote
Old 06-03-2016, 11:16 PM   #2
Texas Realtor's Avatar
I had exact same issue with same side. I had mine replaced and upgraded my front lights to better bulb quality as well. Seems like it maybe fairly common
Texas Realtor is offline   Reply With Quote
Old 06-04-2016, 10:37 AM   #3
The Head light for your Berkshire is the same as a 2001 Toyota Highlander.
I had the same issue on the passenger side.
The part number(s) I used on My 2011 is TYC20-6173 Passenger and TYC 20-6174 Driver.
Pat
Cudntherd
2011 Berkshire 390BH-60
cudntherd is offline   Reply With Quote
Old 06-04-2016, 11:42 AM   #4
Thank you very much for the info.
Would this be a do it yourself job for a brain dead idiot like me ... or do I need to take it in and dish out a 200 per hour shop rate
Old 06-04-2016, 11:55 AM   #5
I replaced mine. It's not difficult if you have some mechanical knowledge and hand tools. The access from below or the generator compartment will be the challenge.
The headlight is available on line or at most auto parts stores.
I would purchase the headlight and then take the RV to a independent body or auto Repair shop and have them give you an estimate for replacement.
Pat
Cudntherd
Old 06-04-2016, 12:18 PM   #6
I sent you a private message about some of the Headlight assemblies and price I found on line.
Pat
Cudntherd
Old 06-04-2016, 03:41 PM   #7
gasman94's Avatar
Don't know if it will help, but I was under the coach the other day and noticed that there are areas where moisture can enter the lights. I will try to seal mine up and see if it helps.
Rich
gasman94 is offline   Reply With Quote
Old 06-04-2016, 07:10 PM   #8
Rich
Headlamps of this type need to be vented or condensation will form on the inside. I would bet that the OP's headlamp vent is crimped or blocked by insects or other parts. If you remove headlamp and used compressed air to dry inside it will return to normal. Only if you find the rubber vent tube and make sure it is not being blocked.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 06-04-2016, 07:45 PM   #9
gasman94's Avatar
Hey, thanks for the info. Didn't realize that.
Rich
light
