Old 10-07-2013, 07:35 PM   #11
ernest917's Avatar
I'm with you... Luckily mine were installed in the correct order....
ernest917 is offline   Reply With Quote
Old 10-08-2013, 04:21 PM   #12
AREA51's Avatar
Boowho,
You can use Microsoft Word or a CADD program to design and layout your panel. If you have all the switch and buttons information you can go on line to most of the manufactures and download their drawing and dimensions. Most are a standard cutout for various switches.
You might consider getting the Nomenclature silkscreened on whatever you decide for a control panel.
The plastic material and perhaps the cutting might be available at:
Johnson Plastics - Engraving Home
There are many vendors that offer this service.
Just a thought.
GOOD LUCK
AREA51
AREA51 is offline   Reply With Quote
Old 10-08-2013, 04:29 PM   #13
Originally Posted by boowho View Post
Jason, I should have added that the installation/owners manual is available on the 'net. Also, if you get serious and need help with the wiring, I can post pics of how I wired it all.
Boowho??
Wait, you may want to think twice before getting help from me!! After everything working fine for over a day, now pretty much everything on the second row of switches (including the new gauges) have quit working. No water pump, no tank heater, no gas water heater.
I'm stumped; I've asked Randy H for a wiring diagram, but haven't heard back yet. Any REAL experts here have a clue?? It's not a fuse problem, BTW.
Anyone??
Boowho??
boowho is offline   Reply With Quote
Old 10-08-2013, 05:43 PM   #14
CLASS "A" Senior Member
cfsoistman's Avatar
Sounds like the ground or common may have come loose.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 10-09-2013, 03:37 PM   #15
Thanks for that tip. I checked for 12V on every pin in the harness for those switch items. The only pin that registered "hot" for 12V in the whole harness was connected to the two way switch for the overhead LR lights.
I had the black prod on my meter connected to a ground wire in the same harness.
It would appear to me that I have somehow lost 12V + power to that harness. I just don't know where to start looking. Apparently, no two coaches from FR are identical and because of this nothing is written down with regard to cable location.
I have a wire tracer, so will try connecting the sender of it to the harness on the 12V fuse panel. Anyone know if there is more than one location for 12V fuses on the 2011 Berk 390?? I have one inside the left side outside door panel by the driver's seat, but could there be others??
Any other thought?
Boowho??
Old 10-09-2013, 03:58 PM   #16
ernest917's Avatar
Most of my fuses are in front outside compartment drivers side,,,, Compartment in front of propane tank....
Old 10-09-2013, 04:56 PM   #17
Thanks..... Yeah, I just checked again and I DID have a blown fuse. Not sure how I missed it before, but that was in fact the problem.
Why the fuse failed so long after I'd finished the install is anyone's guess. Hopefully, it won't blow again.
So...... Now having gained my confidence back, if anyone needs pics of how the installation goes, I'll be happy to post.
Boowho??
Old 10-10-2013, 06:02 PM   #18
Please put on a photo of your upgrade ... would love to see it
lefaivre is offline   Reply With Quote
