Old 02-16-2015, 08:34 AM   #1
Convert water heater to On-demand
I have an 11' 390BH. Has anyone converted their water heater to an insta-hot, on demand type?
Looking for how-to or advice.
Thanks,
Matt
mrcerretti is offline   Reply With Quote
Old 02-16-2015, 08:39 AM   #2
My 2011 had on demand. Why are you wanting to switch it. There are several products out there none are perfect.
Old 02-16-2015, 08:49 AM   #3
Our water heater quit working. And we like to take showers for longer than four minutes
Old 02-16-2015, 09:12 AM   #4
A couple of thoughts. The Garrard is what most of the Berkshires come with. They are coming out with a Gen 3 that promises temperature control. Atwood also makes one and I know Mike and Sylvia put one in their MH maybe they will chime in. I saw a new product at the Tampa RV show but I can't find the literature I picked up. It looked very promising and offered full temp control. The problem with that system is the covers don't match. And they are white plastic. At any rate if you change the WH to a inline system you will have the added expense of a new cover and getting it painted. I wonder if you have room for a ten gallon system. I have heard that if you run them with both heat sources running it works almost like an in line system. If I find the name of the new system I will get it to you.
Old 02-16-2015, 09:51 AM   #5
thanks PHil
Thanks for the info!! Maybe we will try for a 10 gallon system, or a second 5 gallon holding tank. We dont want to have the grill painting, match problems.
Thank you.
Old 02-16-2015, 10:02 AM   #6
Witch Doctor's Avatar
Thank you.
I would just add a pressure holding tank like you use for wells. It would also cut down on either the electrical used which really doesn't matter but propane would.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 02-16-2015, 10:26 AM   #7
caper's Avatar
They make on tank-less heaters that are the same size as the tanked heaters and the existing panel will fit.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-16-2015, 11:21 AM   #8
You will at least need to cut a hole in the existing panel. Click image for larger version
Name:	ImageUploadedByForest River Forums1424107267.663521.jpg
ID:	69728Click image for larger version
Name:	ImageUploadedByForest River Forums1424107282.470949.jpg
Old 02-16-2015, 11:51 AM   #9
caper's Avatar
Suburban make a 16 gal water heater that used the same door and the 10 gal. it is 6.5" deeper.
Terry and Janet
2007 Ford F150
Old 02-16-2015, 12:43 PM   #10
Blue Ridge 3600
Precision Temp makes one that fits in the same space as a 10 gal. Had it for 3 years without a bit of trouble. I little expensive but quality and easy to install.
billg is offline   Reply With Quote
heater, water, water heater
