03-26-2015, 01:58 PM
Coolant/Anti-Freeze
Hi All-
Taking the rig out of winter storage and the 'low coolant' light is on. Engine kicks itself off after a minute. Trying to find the right coolant to put in and top it off. I've called Forest River, Cummins and Freightliner. Freightliner told me I can get any coolant off the shelf at NAPA, AutoZone etc, as long as it is Ethylene Glycol Based, Heavy Duty with SCA.
Just wondering if you have topped of your coolant, what did you use? And if I buy pre-mixed, I don't need to worry about the 50/50 dilute ratio, correct?
I have the Cummins ISB 6.7 340.
Thanks for the thoughts.
Mike
Mike Hollar
2014 Berkshire 390BH-40
2012 Chevy Equinox - TOAD
03-26-2015, 02:33 PM
Poly freeze gold "for all makes" already pre diluted 50/50.
03-26-2015, 06:33 PM
My only concern would be if it is dexcool or the regular stuff. Dexcool is pink vs green for the other. You can't mix the two. Jerry
2005 GMC Sierra 2500HD, Duramax CC/SB
2022 Rockwood 2613 BS
03-27-2015, 07:42 AM
cummins use FleetCharge. You can get it at Tractor Supply if one is near you.
03-27-2015, 07:51 AM
That's why I recommended polyfreeze.
Works either way regardless of color or style.
It's also precharged for diesel.
03-27-2015, 08:15 AM
I'll stick to 50/50 premixed thanks
03-27-2015, 08:22 AM
I have well water high in iron and IM lazy. 50/50 premixed
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
03-27-2015, 09:27 AM
This thread was being hijacked with off-topic and irrelevant to the question at hand posts. This is not helpful to the OP. As such, all of these posts were moved to the off-topic forum.
Please try to keep this thread on topic and help Mike out.
2011 Flagstaff 831 RLBSS
03-27-2015, 09:28 AM
Me too.
03-27-2015, 10:53 PM
Thank you for the help. I was able to find Fleet Guard with SCA right down the road at an auto store. Same color. Pink.
As always, appreciate the help.
Mike Hollar
03-28-2015, 08:57 AM
Mike,
Not sure that Fleet Guard and FleetCharge have the same chemical make up. Make sure that you check it out before you add it. As was posted earlier by silver, Freightliner puts FleetCharge in the coaches we have. I would call the Freightliner help line to double check what should be used.
Tom and Margaret
2014 Berkshire 390bh-60
03-28-2015, 09:33 AM
You may also want to determine why the coolant is low - loose hose clamp, leaking gaskets, etc. Last thing we need is to have the engine shut off while cruising down the highway to our favorite vacation spot.
2010 Surveyor 294
2006 Ford E-350 Van 5.4
03-28-2015, 11:11 AM
2013 Berkshire 390 BH-60
Mine was low last year after sitting all winter. My diesel mechanic advised me this is a normal occurance and to add to the line in the spring.
Mike
2013 Berkshire 390BH-60
03-28-2015, 11:15 AM
This primarily from a "cold leak"
@ a hose fitting .
My semi tractor does it every winter.
Never add coolant in the summer but in the winter yes.
Turbs
03-28-2015, 11:20 AM
@ a hose fitting .
Turbs
If it is low in the summer, why can you not add?
03-28-2015, 11:21 AM
Never low in the summer.
Turbs
03-28-2015, 11:23 AM
Turbs
Are you talking about yours specifically or in general?
03-28-2015, 11:26 AM
Yes mine specifically,
All summer long the tank remains full
Once it starts to get cold the tank will go down some.
Eventually I'll have to add because it's low enough that it goes into limp mode.
Turbs
03-28-2015, 11:30 AM
Turbs
That's weird to say the least.
03-28-2015, 11:38 AM
Sounds like a faulty pressure cap.
