Old 11-18-2010, 05:22 PM   #11
tmmar's Avatar
Alex,
When I had mine weighed, they were not able to do each corner but if I were you, I would have the rear weight checked. The approx 13600 pounds of the rear coach seems low. Mine came in at 17600 lbs for the rear. With these weights, the charts said that 95 lbs pressure is correct.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-23-2010, 12:52 AM   #12
amarzano's Avatar
Just a quick update.
I spoke to forest river today. They politely told me the rear weights could not be correct. I should be at approx 8500lbs per side for the rear and about 4500 per side for the fronts.
I will re-weigh the coach over the weekend and at least get total axel weights.
Originally Posted by amarzano View Post
I know this is an old thread - but thought it would be helpful for other owners to see what the coaches weigh and get some additional reference points.
We had our coach weighed today..
Front Left: 5200 lbs Front Right: 5190 lbs
Rear Left: 5120 lbs Rear Right: 8540 lbs
My first reaction - Holy Crap - someone must have made a mistake..
Any other owners see such a big difference in the Right Rear? I know this is where the Fridge / Washer / Dryer / Fresh Water tank / etc. sit.. Just wondering if this is normal..
I did NOT have the family in the coach at the time - but figure that is only about 250 lbs (small kids) or so - and that would be distributed mostly over the front..
Anyone able to validate the correct Tire Presssure I should be running?
Thank you,
Alex
2011 Berkshire 390BH-60
Cummins ISB 360hp/800ft-lbs DEF
Allison 3000
amarzano is offline   Reply With Quote
Old 11-23-2010, 06:14 PM   #13
amarzano's Avatar
Forest River followed up and provided the following numbers:
FR - 4614 FL - 4586
RR - 8458 RL - 8362
This is for MY coach as it was when it left the factory. Apparently - they weigh each unit as it leaves. I thought this was pretty interesting..
Allison 3000
Old 11-28-2010, 10:41 PM   #14
amarzano's Avatar
Thank you all again for the advice.
I had the coach weighed at a CAT scale before our trip. This is close to
Loaded, minus a DW and kid.
Front: 10,020lbs
Rear: 17,280lbs
This seems to be in line with what FR told me and what others have posted.
The original weights I posted were obviously wrong. I still have not been able
To have each wheel weighed, and will keep trying.
I will also weigh the coach on the way back from the weekend - with everyone on board and post that tomorrow..
Allison 3000
Old 11-29-2010, 06:05 PM   #15
amarzano's Avatar
Just got back from the weekend..
Here are the updated weights with everyone and all the junk on board..
Front: 10,160 lbs
Rear: 17,520 lbs
This translates to about 100 - 105 psi Front and 95 psi Rear. I know the proper way is to weigh each tire to find out if one side weighs more than the other - but based on what FR told me and how tough it seems to find someplace to weigh the 4 tires accurately in my area - I think we are pretty good with the above.
Alex
Allison 3000
berkshire
