Old 02-19-2016, 09:31 PM   #21
Originally Posted by rockfordroo View Post
Do motorhomes even need chassis lube? Most cars and trucks these days have "permanently" lubed joints - but maybe I'm just ignorant about MH's.
Almost sounds like a gimmick. I know auto repair shops still push "tuneups" to the ignorant, even though new cars don't have points, condensers, distributor caps or most of the other stuff you replaced or adjusted during a "tuneup."
I don't remember the exact number without looking it up but I believe there are around 110 lube points on a Berkshire chassis. Also have things like ride height and axle lube oil that needs serviced. You can easily spend a 1000 dollars for a service.
Old 02-20-2016, 09:45 AM   #22
RKNOLA's Avatar
Yes, MHs are different than cars and trucks. It isn't a gimmick. There are numerous lube points throughout the chassis.
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 02-20-2016, 10:50 AM   #23
Now I know - Thanks.
2011 Traverse LT, 3.6L, FWD
Old 02-20-2016, 11:44 AM   #24
fedexflyer's Avatar
Haven't experienced any other Speedco centers, but glad to see they are all over. I had my oil changed with Rotella, all oil and fuel filters changed, full chassis lube and fluid check. I sat and watched the technicians do the service. I've done it myself in the past but I can't do the whole service for that price. To each his own, but I'll use them again.
USCG Ret
2011 Sportscoach Pathfinder 405FK
2018 Jeep Wrangler Unlimited Rubicon Recon
fedexflyer is offline   Reply With Quote
Old 02-21-2016, 08:26 AM   #25
I-RV's Avatar
Originally Posted by AquaMan View Post
Do you do this annually? It says 36 month service.
Freightliner and Cummins recommend doing service every 15,000 mi or 12 months, whichever comes first. Most of us probably fit into the annual category. Freightliner had a service sheet for each 12 month period. Some items change between years. For example, you only need to get the tranny filter changed every two years. Change of tranny fluid, radiator coolant, air dryer, etc., have their own periods. I just showed the service for the 36 month service as an example.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 02-21-2016, 04:49 PM   #26
Name:	ImageUploadedByForest River Forums1456094948.309464.jpg
Here is the latest and greatest.
Paul
2015 XL 40QL-60
2015 Jeep Wrangler Unltd. Sahara
Paulie Boy is offline   Reply With Quote
Old 02-21-2016, 05:23 PM   #27
tnbendr's Avatar
Nice chart, thanks Paul!
Ben & Michelle
2015 Berkshire 38A
2005 Jeep Wrangler toad
tnbendr is offline   Reply With Quote
Old 02-22-2016, 03:47 PM   #28
Pleasure is all mine Ben
Paul
2015 XL 40QL-60
Old 02-25-2016, 09:49 PM   #29
Texas Realtor's Avatar
Just had my inspection, oil changes on engine and generators(18 Qrts) fuel filters replaced fluids checked and topped off,!tires inspected and check for pressure. $322.00
Texas Realtor is offline   Reply With Quote
Old 02-26-2016, 12:44 AM   #30
Cost of oil change
My last time I had this done was on October 2015 it was the 35,000 mile check. Freightliner did the check and was right at $950.00 dollars but had it done at a Freightliner Oasis. In Rapid City SD. Had it done before we left for a six month tour. ( Freightliners check list)
outloud is offline   Reply With Quote
